Farmall 1456 Custom Cab Interior Questions
Thank you! I appreciate the response. How about for the cab bushings? I’m guessing I will just need to find something similar to factory but if there’s any that are recommended I would rather go that route
52320.thumb.jpeg.12d3857e3a6f5855c02d9a1641f90fc0.jpeg52320.thumb.jpeg.12d3857e3a6f5855c02d9a1641f90fc0.jpeg52318.thumb.jpeg.7e46954ff0d59377c037abf864e84d49.jpeg52322.thumb.jpeg.4889e9866dbabf29c60faab6dfaeb0e9.jpeg
These are pictures of the IH Diamond Cab that my brother and I just refurbished for my 1456.  The cab foam upholstery kit and the door seal kits were from Fehr Cab.  Now, the only downside is that their upholstery kit is for a 66 series Diamond Cab, and not a 26/56 series Diamond Cab.  There are subtle differences which will require some cutting and trimming.  If you order from them, be sure to tell them it's for a 56 series, and they'll include some additional foam that you can cut and shape to fit the areas the 66 series kit doesn't normally cover.
As for the rubber ISO mount bushings, I never found a source for replacements.  We ended up reusing my old ones, they were still in decent shape.
About 20 years ago I got a set of cab bushings for my 1066 diamond cab from the local Navistar dealer. They were nla from cih. I took the old ones to the truck dealer and asked if they had anything similar. Turs out it was the same as a truck cab mount they had on the shelf!
Sorry, I don't have the part number anymore.
Thx-Ace
22 hours ago, Senecaagman said:
Fehr made me these custom covers for the batteries and should still have the pattern on-hand if interested.
Nice!  I will have to check on one of those!  What did you do for boots around the pedals?
I can tell you that on mine, we used the pedal boots that Fehr offers for the 66 series.  We just didn't use the boot retainer plates for a 66 series (even though I did find a NOS set)
Nebraska1206, do you have any pics showing the cab on the tractor? Inside looks sharp! Nice job!
Sure do!  Here's the whole tractor
FB_IMG_1654997356220.thumb.jpg.a628e367fb3d1047325e82b5b0c92299.jpgFB_IMG_1654997344428.thumb.jpg.25da1df17b3b921bdb75afd20ca6016f.jpg
  • Like 7
11 hours ago, stronger800 said:
28B26583-DD96-4170-B8A9-361FF3C684D0.thumb.jpeg.ef9c5dab1925343aacc6d0625da993e9.jpeg533B9E48-BFED-42B2-A479-84CC50D7E5E6.thumb.jpeg.08d42fa81ea1cce044ad4e467bb81c8b.jpeg95129E94-BE8B-43C0-A050-511B86214894.thumb.jpeg.b107dcc7a6614308d80fb365d0c6664d.jpeg
i want in too.  I’m betting I have The only interior marker lights and 1970’s wood paneling.
Man, your 1466 reminds me so much of one I used to see South of Norfolk, NE ever so often.  Same setup, 1466, Diamond cab, Firestone Field & Road rear tires (20.8-38's on the one I remember), and factory IH muffler.
Very nice! Thank you for adding these pictures!
You have a good looking tractor and cab set up too!
Very nice!
