dannyredfan Posted June 26, 2022 Share Posted June 26, 2022 like they say, not enough hp can’t get it done. 😄😏. Or something like that. Lol no the rake tractor went down, and this was the most handy. got it done lol. 20 hp. per wheel. feel free to add to this. What have you overkilled? 1 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted June 26, 2022 Share Posted June 26, 2022 "There's no kill....like overkill" 3 2 Quote Link to comment Share on other sites More sharing options...
Ihfan4life Posted June 26, 2022 Share Posted June 26, 2022 What happened with your side panel?😢 1 Quote Link to comment Share on other sites More sharing options...
B.B. Posted June 26, 2022 Share Posted June 26, 2022 I see nothing wrong here. AC is a good thing on a haying tractor 🚜 2 Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted June 26, 2022 Author Share Posted June 26, 2022 23 minutes ago, Ihfan4life said: What happened with your side panel?😢 It was that way when I bought it. Probably the reason I could afford it lol. It's got a few dents and dings. But still looks good at 50' 3 1 Quote Link to comment Share on other sites More sharing options...
junkandcattle Posted June 26, 2022 Share Posted June 26, 2022 I went 15 hp per wheel last year on about 60 acres because the ride was much nicer 1 Quote Link to comment Share on other sites More sharing options...
Reichow7120 Posted June 26, 2022 Share Posted June 26, 2022 Have ran a 5 bar JD rolabar rake on our 2 7120s a couple of times. One time we were down a couple of tractors and at the time we didn't have the bullpen we have now to pull from. Used the FWA 7120 that time. Second time we had hay down in a couple of places miles apart. Didn't want to pull tractors off of the one place to rake at the other. The 2wd 7120 was sitting there on the haybine waiting for me to cut the rest. So we pulled one of our rakes over with the pickup and raked with that. Not quite as much of overkill but still plenty. Pulled a 6 row corn planter with a 7230 Magnum we bought last year to upgrade to a 12 row planter. Planter didn't come but we still used the tractor until we had a problem with it 3/4 the way through corn planting and it got parked until after planting for fixing. Also ran a ancient New Holland 850 round baler with the 7230 a couple weeks ago. It was unhooked so with a PTO adapter it ran it. 6 Quote Link to comment Share on other sites More sharing options...
nc1112 Posted June 26, 2022 Share Posted June 26, 2022 Our magnum has been used plenty to pull small bar rake or haybine either because it was handy or had the best ac. Same bar rake and small 22' disk was pulled with the steiger because it happened to be the free tractor at the time. 3 Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted June 26, 2022 Author Share Posted June 26, 2022 42 minutes ago, nc1112 said: Our magnum has been used plenty to pull small bar rake or haybine either because it was handy or had the best ac. Same bar rake and small 22' disk was pulled with the steiger because it happened to be the free tractor at the time. I would like to have seem the steiger raking 1 4 Quote Link to comment Share on other sites More sharing options...
midnightman Posted June 26, 2022 Share Posted June 26, 2022 57 minutes ago, nc1112 said: Our magnum has been used plenty to pull small bar rake or haybine either because it was handy or had the best ac. Same bar rake and small 22' disk was pulled with the steiger because it happened to be the free tractor at the time. If you ever got stuck in a wet spot with the Steiger pulling the rake it would mean you really shouldn’t have been there. If the neighbors seen it, people would talk about it for years.🤣 4 Quote Link to comment Share on other sites More sharing options...
Big Bud guy Posted June 26, 2022 Share Posted June 26, 2022 For us JD 8300 on a 348 square baler. My cousin ran his post pounder on a JD 8295R because the parking brake didn’t work on their 5488. Quote Link to comment Share on other sites More sharing options...
db1486 Posted June 26, 2022 Share Posted June 26, 2022 We've pulled the 14 wheel v rake with the 4494 a few times, round baled with it. 3788 running a 10" swing auger. Sometimes you gotta use what's available if another goes down. Then there has been a few years, and I think this year might be the same, where we needed a 4wd to pull the rake it was so wet. A couple times I sunk the 766 bad enough on the hay fields we just parked it and put the 4166 on it. Probably the funniest looking setup we had for a while was a 70 foot 500 gallon wheeled boom sprayer behind the 4494. It handled it no problem lol. Looked hilarious but never got stuck. Actually had to be careful with it because if you went though too much water it was hard on the booms lol. I don't miss that sprayer lol Quote Link to comment Share on other sites More sharing options...
885 Posted June 26, 2022 Share Posted June 26, 2022 Raked hay with a v rake and a f150 before. Just went round and round cause the truck didn't have hydraulics lol. Pulled a 4 basket tedder that only needed a 35 hp tractor with a 120 horse tractor because it had air conditioning. Pulled a old 2 row corn planter with a 80 hp tractor. 1 Quote Link to comment Share on other sites More sharing options...
Delta88 Posted June 26, 2022 Share Posted June 26, 2022 The cab and ac makes the overkill discussion non relevant. 4 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted June 26, 2022 Share Posted June 26, 2022 12 minutes ago, Delta88 said: The cab and ac makes the overkill discussion non relevant. I could really get into that sort of thing with AC. Even a cab wide open. Baking in the sun, not for me 1 Quote Link to comment Share on other sites More sharing options...
Big Bud guy Posted June 26, 2022 Share Posted June 26, 2022 19 minutes ago, 885 said: Raked hay with a v rake and a f150 before. Just went round and round cause the truck didn't have hydraulics lol. Pulled a 4 basket tedder that only needed a 35 hp tractor with a 120 horse tractor because it had air conditioning. Pulled a old 2 row corn planter with a 80 hp tractor. Back in the day we occasionally pulled our MH rake with our IH R series pickup. Ground driven rake and i image more comfortable then the M Quote Link to comment Share on other sites More sharing options...
oleman Posted June 26, 2022 Share Posted June 26, 2022 BUT how can you afford to rake at the cost of operation per hour on that machine? Our little D179 powered 464 does not burn 1 GPH running that little size rake. But you do have climate control and all the other nifty features! Quote Link to comment Share on other sites More sharing options...
acem Posted June 26, 2022 Share Posted June 26, 2022 I've moved round bales of hay with my 4366. It was baled late in the Fallon some wet ground. We got a big rain... it was the only thing I had that would get it out! My neighbor is pulling his 20ft jd 750 with his jd 9400. It wasn't hooked up to anything. Thx-Ace. Quote Link to comment Share on other sites More sharing options...
1256pickett Posted June 26, 2022 Share Posted June 26, 2022 4 hours ago, 885 said: Raked hay with a v rake and a f150 before. Just went round and round cause the truck didn't have hydraulics lol. Pulled a 4 basket tedder that only needed a 35 hp tractor with a 120 horse tractor because it had air conditioning. Pulled a old 2 row corn planter with a 80 hp tractor. When I was a kid a guy up the road rented the neighbors alfalfa field and raked it regularly with his pickup. For 2 or 3 years. He didn’t want to road the tractor a couple miles. Quote Link to comment Share on other sites More sharing options...
B.B. Posted June 26, 2022 Share Posted June 26, 2022 Growing up I raked a lot of hay on a JD H and an Allis B and a C. The orange tractors was my dad’s and the H belonged to my great uncle Roscoe who lived across street. 88 series with AC would of been a dream to that kid lol Quote Link to comment Share on other sites More sharing options...
1256pickett Posted June 26, 2022 Share Posted June 26, 2022 I can’t find the picture but I went the other way a few years ago. Moving stuff around in the shed and had the round baler hooked to my cub 185. 1 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted June 26, 2022 Share Posted June 26, 2022 17 minutes ago, 1256pickett said: I can’t find the picture but I went the other way a few years ago. Moving stuff around in the shed and had the round baler hooked to my cub 185. Had a 4 row Cyclo 400 on a Cub Cadet 100 one year doing the same thing! Was easier to get it jockyed in its parking place! Quote Link to comment Share on other sites More sharing options...
ChrisNY Posted June 27, 2022 Share Posted June 27, 2022 wife wanted a shrub removed…no problem 6 4 Quote Link to comment Share on other sites More sharing options...
ChrisNY Posted June 27, 2022 Share Posted June 27, 2022 5 hours ago, Big Bud guy said: Back in the day we occasionally pulled our MH rake with our IH R series pickup. Ground driven rake and i image more comfortable then the M We raked a lot of hay with a Jeep CJ5 and New Holland bar rake. Pulled it with Honda Foreman 4 wheeler as well. On the flip side, pulled it with a 4166 too. Lol Quote Link to comment Share on other sites More sharing options...
ChrisNY Posted June 27, 2022 Share Posted June 27, 2022 Overkill or Underkill?? 8 Quote Link to comment Share on other sites More sharing options...
