DT 407 cam bearings
I’m in the process of overhauling a 1256, and I need at least the front cam bearing, or I’d even buy the kit just to proceed with this!! Any help locating a set, or front bearing would be greatly appreciated!
Last one I done back last summer, ended up having my dealer do a "dealer search" and found a set in ND. They came in, bearings where in original International Harvester parts boxes!
That’s how I got the 3 I have, but I’m one short! Par for the course! 🤦🏼‍♂️
  • Sad 1
7 hours ago, Farmall 1466 said:
"Brand: Reliance" Oh no, here we go again...
We are at the point, that’s all we are going to get, so might as well just get used to it.  I don’t want to, but I need an engine running!
It is something that is inevitable. There are fewer and fewer manufacturers to make these and the market is shrinking. In some way, we should be happy that Reliance still produces such an abundant amount of different old products, all be it that their quality isn't particullarly top notch..
Wouldn't that be a bogey?
Sorry, it's early.
I wonder what would be involved in machining a bearing.
Sorry, it's early.
I don’t golf, but your probably right!🤣
I’m hoping I can source the front one, or a kit yet! The dura bond bearing in the link above show the kit is available, until you order, then before submitting the order it says not all parts are available.
  • 1 month later...
I check on the dura bond bearings again tonight, through summit racing, now they pushed them out from September to October! Sure would be nice to find at least the front bearing, so I can move forward with this overhaul!
