TC5 man Posted June 15, 2022 Share Posted June 15, 2022 I am looking for source of information to show me the steps to remove the engine to replace ring gear. While it’s out should I do a rebuild on entire engine the machine is a TC5. Serial # C 10819 with a Drott Skid Shovel Quote Link to comment Share on other sites More sharing options...
R190 Posted June 17, 2022 Share Posted June 17, 2022 Does it need a rebuild? Without knowing more it would be foolish to give advice on rebuilding it . As far as pulling the engine I know of no resource jut the adviise to unhook everythng and I am pretty sure you must pull the radiator and support to slide the engine forward and lift out. t Quote Link to comment Share on other sites More sharing options...
hardtail Posted June 18, 2022 Share Posted June 18, 2022 I think he needs to replace the flywheel ring gear? Quote Link to comment Share on other sites More sharing options...
TC5 man Posted June 19, 2022 Author Share Posted June 19, 2022 Thanks I appreciate the two replies that I have received. The problem has been solved. After a more detailed inspection with my inspection camera and bumping my head a couple dozen times I have determined the ring gear is fine. Starter definitely will be replaced as the mounting flange had broken in a couple of places and the starter was not in a proper position on a starting attempt and it incurred some damage.The whole exercise was an incentive to lose some weight to make It easier to get under the machine. thanks again Quote Link to comment Share on other sites More sharing options...
Ian Beale Posted June 19, 2022 Share Posted June 19, 2022 2 hours ago, TC5 man said: The whole exercise was an incentive to lose some weight to make It easier to get under the machine. If you have a blade and the machine is running you can cheat a bit by pushing up two parallel mounds and running the dozer up on them Quote Link to comment Share on other sites More sharing options...
mmi Posted June 20, 2022 Share Posted June 20, 2022 On 6/18/2022 at 10:41 PM, Ian Beale said: If you have a blade and the machine is running you can cheat a bit by pushing up two parallel mounds and running the dozer up on them if dead a jack and 2 short ties work in the shop,or 2, 8' ties and some leaders under power (as every winter) really not much can be done under them,as 135 starters are top rear left crammed ,for short wrenchs and long extensions,well behind ANY accessories Quote Link to comment Share on other sites More sharing options...
