LipRipper3006 Posted June 15 Share Posted June 15 Here are the numbers that I can find off these sleeve piston kits. Supposedly they are for a SuperMD/MTA. He only has 3 so I would need a 4th but have only seen diesel pistons that are flat top with a bowl near the center. Does anyone know what they fit or if I can even find a 4th to have a matching set? Quote Link to comment Share on other sites More sharing options...
DWV Posted June 15 Share Posted June 15 Without double checking I would say that is for a SM gas. IH pistons for a D-264 and D-281 start with the number 2. May have guessed wrong, could be a 5000 altitude for a C-248. Quote Link to comment Share on other sites More sharing options...
R190 Posted June 15 Share Posted June 15 defiantly gas pistons whats the bore diameter. Quote Link to comment Share on other sites More sharing options...
LipRipper3006 Posted June 15 Author Share Posted June 15 4in bore but the pistons are long and the liners are thick. Quote Link to comment Share on other sites More sharing options...
Nebraska1206 Posted June 15 Share Posted June 15 What I could find, based on those numbers, says they're for a Farmall M. Quote Link to comment Share on other sites More sharing options...
DWV Posted June 16 Share Posted June 16 15 hours ago, LipRipper3006 said: 4in bore but the pistons are long and the liners are thick. If for a D-264 4 inch bore the IH piston number would be 264320R1 or higher suffix number. Or if going to thin wall sleeves the piston number is 277071R1. One sleeve assembly 264338R96 for 4 1nch bore. 277077R91 for 4.125 bore. Sleeve, pistons, pin and rings. Hard to find. Quote Link to comment Share on other sites More sharing options...
