Td6 skid shovel progress
I have never tried to put more GPM through a control valve than they are rated for but think you pump would be closer to 50 than 25. Ok went back and looked at your pictures again and the rams are smaller than I remembered, so a good chance it could be just fine.
Playing with pumps and valves I had or got out of a junkyard cheap, I learned 30 or 40% less flow makes a world of difference all in a bad way.
12 hours ago, brian falcone said:
I think the td6 was around 27gpm
That is a good number, my 62 series with increased capacity hydraulics is rated 33 gpm @ 1800 rpm, the four cylinder is a lower rpm engine.
I've got parts!!!
Took a ride to check out the machine and the valve looked good  but couldn't find the pump in the parts pile but he thinks he has it so I made an offer. He agreed so I filled my civic with as many parts as I could.  Bottom is ehh....   Pads are worn. Rails are thin but bushings still round. Sprockets, idlers and rollers looked ok.  Looking at what's left of the machine I'm pretty sure the f250 and 5 ton trailer will work. He said it rolled onto the trailer last year no problem and it was covered with a tarp.  So now between the 2 of them im hoping I will be good for everything I need.
Oil pan, valve cover, fan in the back seat...lol
The pin bosses aren't marked so that's a good sign on the rollers 😊
Honda will need to rename their interior color, PA dust
The little Honda earned its money this weekend.
1 hour ago, brian falcone said:
Just need to clean the car before Karen gets back from florida.
Hope it doesn't smell like gear oil or diesel fuel when you are done . Would be dead give away.😄
You can tell we are getting old covering tracks of iron buying, when we were younger there would have been different smells to worry about 😳
  • Haha 2
Well....12 hours later and it's home. We tried to roll it off the trailer and onto mine but low and behold it won't roll....so I'm assuming  brakes are stuck. Good thing over overhead cranes. Trailer held up well but truck  only averaged 8.5mpg pulling it home
I don't know about those two parts, but the wrench looks like it would be for the track adjustment, you could slip a pipe on it for more leverage. The problem with that type of adjustment is from non use, then everything gets rust. Nice to find all of those goodies.
DWF
Maybe the 2 rectangular pieces are the lower engine side skirts that sit on top of the frame.  Then the side shields would sit on top of them.
On 8/8/2022 at 8:46 AM, brian falcone said:
Ok...going through the loose parts...what are the 2 rectangle parts on the bottom ? Are they the floor boards that go by each brake pedal ? Also is that the wrench the dealer supplied to tighten the tracks?
Floor boards IIRC
Later - I don't remember that tab towards the back on ours, I think they had a bolt through thye side skirts
And the spanner is probably for track adjusting but it doesn't look like the IH one that came with ours
