86 electrical outlet troubleshooting
Kycowboy
Trying to hook up a jd 566 round baler to my 1086 and I don’t have any power to my plug on the back of my tractor. I’ve never needed it before this so I’ve never even looked at it. Hoping someone can point me in the right direction
That plug more than likely has 3 wires going to it
Right and left turn signals and or flashers and the ground.
I don't think they were wired with constant hot or key switch hot.
You will have to add it.   If you have an owners manual it will tell you what each prong does
What are you using on your baler that you need a live power feed? most of them balers have their own wire harness from the monitor anyway
I had to add the wire for tail lights and the baler I have is the only thing on the place with tail lights. It does have it's own harness to run the functions of the bailer. I just ran the wire up and tied in with the power feed to the right side tail light on the tractor.
I've had to add the live power wire to the plug to run our 14/1682 combines. I just run a wire to one battery and put an alligator clip on it. Only need it a few weeks of the year
I've always wired any monitors thru the fused power block under the steering console so much easier and safer
The controller box for marker arms and folding on the 900 horizontal rear fold planter came thru the harness that used the seven pin outlet on back as well as the warning lights.
