farmall m clutch rebuilder
Dell
im look for someone to take my  clutch and disk and rebuild it. id like heaver spring put in for pulling. any help on who dose this type of work???
if you still have an 11" clutch get a super m 400 or 450 flywheel and get a clutch kit for a 986. Hy Capacity can fix you up. I am a dealer for them.
Will the 400 or 450 flywheel bolt up to the older m crank! Or dose that need to get changed too
Yes, the 400 and 450 flywheel bolts up without modification. I did that to a turbocharged M a few years ago. I used a clutch with heavier springs and a disc from Hy-Capacity.
It will bolt right up.
