hobbyfarm Posted May 22 Share Posted May 22 Had a bearing go out on the discbine conditioner. It was a fight but I got it done. I applaud you guys that does this every day. I'm sure you learn tricks after awhile but still some things aren't easy. A combination of heating it dull red hot and a gear puller got it done. Harder then it looks for an amateur. 7 Quote Link to comment Share on other sites More sharing options...
brahamfireman Posted May 22 Share Posted May 22 Tips and tricks. Usually with a bearing that far gone you can remove everything but the inner race on the shaft. If there's not much of a fire danger you can torch off the inner race by blowing the slag at a 90 degree angle to the shaft. If you go slow, but quick you'll never even knick the shaft. Only need to torch off the "top", the heat will expand the remaining race parts and you can slide it right off. 3 Quote Link to comment Share on other sites More sharing options...
Cattech Posted May 22 Share Posted May 22 Kudos for a guy to DIY. Always appreciate the acknowledgment.... Used to love this Snap-on poster. 2 Quote Link to comment Share on other sites More sharing options...
bitty Posted May 22 Share Posted May 22 Hesston ? If so they have a cast housing bearings available that last much better Quote Link to comment Share on other sites More sharing options...
hobbyfarm Posted May 22 Author Share Posted May 22 6 hours ago, bitty said: Hesston ? If so they have a cast housing bearings available that last much better CIH 8312. I'm not sure of the lineage but very much the same as Hesston. Zimmermans sold me an agco packaged bearing. Hope to keep this thing going a few more years. Im guessing it has a lot of acres through it. I've had it about 3 years. Quote Link to comment Share on other sites More sharing options...
hobbyfarm Posted May 22 Author Share Posted May 22 9 hours ago, brahamfireman said: Tips and tricks. Usually with a bearing that far gone you can remove everything but the inner race on the shaft. If there's not much of a fire danger you can torch off the inner race by blowing the slag at a 90 degree angle to the shaft. If you go slow, but quick you'll never even knick the shaft. Only need to torch off the "top", the heat will expand the remaining race parts and you can slide it right off. Thanks for the tip. All that was left was the inner race and retainer. My torch time is limited. I was kind of scared that if I mess up that piece of shaft I am trouble. Right or wrong cleaned things up with fine sand paper so the new would go on. Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted May 22 Share Posted May 22 18 minutes ago, hobbyfarm said: Thanks for the tip. All that was left was the inner race and retainer. My torch time is limited. I was kind of scared that if I mess up that piece of shaft I am trouble. Right or wrong cleaned things up with fine sand paper so the new would go on. A little sleeve retainer always gives added confidence. Quote Link to comment Share on other sites More sharing options...
Ihfan4life Posted May 22 Share Posted May 22 7 hours ago, bitty said: Hesston ? If so they have a cast housing bearings available that last much better 1 hour ago, hobbyfarm said: CIH 8312. I'm not sure of the lineage but very much the same as Hesston. Zimmermans sold me an agco packaged bearing. Hope to keep this thing going a few more years. Im guessing it has a lot of acres through it. I've had it about 3 years. Pretty sure it’s a New Holland built unit… Quote Link to comment Share on other sites More sharing options...
bitty Posted May 22 Share Posted May 22 13 minutes ago, Ihfan4life said: Pretty sure it’s a New Holland built unit… 1 hour ago, hobbyfarm said: CIH 8312. I'm not sure of the lineage but very much the same as Hesston. Zimmermans sold me an agco packaged bearing. Hope to keep this thing going a few more years. Im guessing it has a lot of acres through it. I've had it about 3 years. I'm confident that it is Heston lineage. We had a 8315 and a dc515 and they were both Heston. Picture of the back would confirm my thoughts 2 Quote Link to comment Share on other sites More sharing options...
Ihfan4life Posted May 22 Share Posted May 22 3 minutes ago, bitty said: I'm confident that it is Heston lineage. We had a 8315 and a dc515 and they were both Heston. Picture of the back would confirm my thoughts I just researched it, you are correct. Heston built this unit. The similarities to a New Holland 1431 is why I thought it was their design. Quote Link to comment Share on other sites More sharing options...
bitty Posted May 22 Share Posted May 22 23 minutes ago, Ihfan4life said: I just researched it, you are correct. Heston built this unit. The similarities to a New Holland 1431 is why I thought it was their design. Fold up end guards for the hesston cutterhead. I actually liked those 15' Hestons we had a lot. Our main problems were they were well used and the conditioner bearings were an issue because the rolls were out of balance from too many rocks through it. The assist roller was the worst for beat up Quote Link to comment Share on other sites More sharing options...
Ihfan4life Posted May 22 Share Posted May 22 1 hour ago, bitty said: Fold up end guards for the hesston cutterhead. I actually liked those 15' Hestons we had a lot. Our main problems were they were well used and the conditioner bearings were an issue because the rolls were out of balance from too many rocks through it. The assist roller was the worst for beat up You mean the hoods? 1431’s are the same Quote Link to comment Share on other sites More sharing options...
bitty Posted May 22 Share Posted May 22 1 hour ago, Ihfan4life said: You mean the hoods? 1431’s are the same No, end hood folds up the side of the Heston and front hoods fold up like the NH does . NH has solid sides. I prefer the NH shielding and the Heston drivetrain and cutterbar 1 Quote Link to comment Share on other sites More sharing options...
jeeper61 Posted May 22 Share Posted May 22 I use a cut off wheel Get down close to the shaft and split it with a chisel 2 Quote Link to comment Share on other sites More sharing options...
Ihfan4life Posted May 22 Share Posted May 22 6 minutes ago, jeeper61 said: I use a cut off wheel Get down close to the shaft and split it with a chisel I’ve done it with a BFH and hit it like you’re mad at it! Wrap it with an old rag so you don’t have shrapnel flying at you 1 Quote Link to comment Share on other sites More sharing options...
hardtail Posted May 22 Share Posted May 22 Almost looks like inner race isn't snug but might be picture? Quote Link to comment Share on other sites More sharing options...
Dasnake Posted May 22 Share Posted May 22 Ive been DIY ever since I had to, sometimes it wasn't pretty and people around me learned some new words, but my hat was ALWAYS doffed to the professional, kudos also. Quote Link to comment Share on other sites More sharing options...
hobbyfarm Posted May 22 Author Share Posted May 22 Only pictures of the back of the machine that I have. It is tucked into the shed now. 1 Quote Link to comment Share on other sites More sharing options...
bitty Posted May 23 Share Posted May 23 Definitely Hesston Quote Link to comment Share on other sites More sharing options...
acem Posted May 23 Share Posted May 23 My 8309 is a little sister to your 8312. It's Hesston. Quote Link to comment Share on other sites More sharing options...
