7140 mfd front wheel seal?
rfh129
The dealer sold me a front wheel seal kit for my 7140 and it has a spacer that goes under the bearing race closest to the hub seal. Is this so the seal rides in a different spot. I have no dust shield so I'm not  maching the hub. Do I subtract the spacer thickness approximately from the shims when setting the rolling torque?
Thanks
Thanks
The bearing spacer is not required in the 71XX, 72XX or 89XX series Magnums.
8 hours ago, 756puller said:
I've never installed one in 15 years, usually on rolling torque if I didn't mess with the bearings I can just reinstall the same shim pack.
It's good practice to always check and adjust the rolling torque before installing a new seal.
