ky966boy Posted May 18 Share Posted May 18 In our fields mowing hay at 7mph you better have seatbelt on 5 is comfortable. Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted May 18 Share Posted May 18 3rd direct on the 656, just over 5mph with 800 Early Riser. Quote Link to comment Share on other sites More sharing options...
766 Man Posted May 18 Share Posted May 18 Rocks are no friend of a Cyclo planter and around here they are quite hard to avoid. With a JD MaxEmerge I can run 4-4.5 MPH in most fields. Quote Link to comment Share on other sites More sharing options...
Lars (midessa) Posted May 18 Share Posted May 18 33 minutes ago, Mr. Plow said: 3rd direct on the 656, just over 5mph with 800 Early Riser. If I recall, we pulled a JD 7000, with a 656 gas, 15.5 x38 in 3rd TA ahead, rpm’s were right close to the 540pto spot on the tach. Usually pulled the TA back if going over a rocky patch, or turning around at the end of the row. Quote Link to comment Share on other sites More sharing options...
Farming Enthusiast Posted May 19 Share Posted May 19 1 hour ago, 766 Man said: Rocks are no friend of a Cyclo planter and around here they are quite hard to avoid. With a JD MaxEmerge I can run 4-4.5 MPH in most fields. You got that right. We run a six row 900 behind a 1086. We reinforced the rows a couple years ago because a couple actually got bent slightly from rocks getting jammed in between. Constantly checking behind you for drag marks in the bad areas. 4-4.5 mph in 3low in bad spots 4low in better areas Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted May 19 Share Posted May 19 2 hours ago, Lars (midessa) said: If I recall, we pulled a JD 7000, with a 656 gas, 15.5 x38 in 3rd TA ahead, rpm’s were right close to the 540pto spot on the tach. Usually pulled the TA back if going over a rocky patch, or turning around at the end of the row. Same here but only have one little rocky spot....other than that it's all just IL black dirt. Usually run it wide open, pull the stick on the headlands......really nice speed combo for turning and planting. You can get in a really good rhythm and if you're careful never overplant more that one row without slowing way down or stopping. Quote Link to comment Share on other sites More sharing options...
Lars (midessa) Posted May 19 Share Posted May 19 This is going back 35 years when I was a farm employee, planting corn was never started before May 15th regardless of the year/weather. Depending on the weather, the goal was to be completed in early June. 700+/- acres with a 4 row planter w/dry fert., livestock chores, breakdowns, etc., we were busy. Quote Link to comment Share on other sites More sharing options...
Rusty_Farmer Posted May 20 Share Posted May 20 Planted sweet corn and indian corn with the #44 4 row and bm in first at quarter throttle this morning. This afternoon back on the 6788 and 16 row cyclo in 6 th gear at pto speed. Tractor says 5.8 mph, planter monitor says 5.😕 Quote Link to comment Share on other sites More sharing options...
Art From Coleman Posted May 20 Share Posted May 20 4 hours ago, Rusty_Farmer said: Tractor says 5.8 mph, planter monitor says 5.😕 That hitchpin soaks up quite a bit of ground speed, doesn't it? 1 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted May 20 Share Posted May 20 9 hours ago, Rusty_Farmer said: Planted sweet corn and indian corn with the #44 4 row and bm in first at quarter throttle this morning. This afternoon back on the 6788 and 16 row cyclo in 6 th gear at pto speed. Tractor says 5.8 mph, planter monitor says 5.😕 Tire slip? Quote Link to comment Share on other sites More sharing options...
acem Posted May 22 Share Posted May 22 I typically plant 3 to 4 mph. Quote Link to comment Share on other sites More sharing options...
DT Fan Posted May 22 Share Posted May 22 I paid a little attention to the tach/speedo on the ten Friday while planting beans. According to this precision device, was running around 4 mph most of the time. If I can remember this next year, going to shift up to L-4 and throttle down, probably save some fuel. Quote Link to comment Share on other sites More sharing options...
Rusty_Farmer Posted May 23 Share Posted May 23 On 5/20/2022 at 9:23 AM, DT Fan said: Tire slip? no not tire slip. Replaced the distance wheel magnets and the monitor won't read the speed correct.Recalibrated a few times and this is as close as it comes. The "old" monitor is slowing down in it's old age😁 Quote Link to comment Share on other sites More sharing options...
