junkandcattle Posted May 15 Share Posted May 15 The one time I wish balls would have dropped and there. Looks like one or two got picked up in that thick oil. 1300 in damage 1 Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted May 15 Share Posted May 15 Just put corn head grease in it, it’ll be fine…. 3 Quote Link to comment Share on other sites More sharing options...
oleman Posted May 15 Share Posted May 15 It will either drive or strip, keep it lubed and make sure the current bearings are good. Use it until to stops driving then get whatever required to make it drive again! Could last for many moons. Between now and then, cornhead grease IS the way to go. Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted May 15 Share Posted May 15 Ring gear will go a bit with a little damage but a damaged pinion gear is like a die grinder on steroids Quote Link to comment Share on other sites More sharing options...
