OLD 10-20 Posted May 11 Share Posted May 11 Trying to check the magneto timing on the WD-6 . Seems the first timing notch does not look like a notch , more of a cross pattern ? Then it has a clear to see notch on the crank pulley . Cranked it by hand to hear the impulse trip on # 1 and it trips well after the notch of the pulley , by just over an inch . Could the cross mark actually be DC ( dead center ) indication refering to the notch coming up ? The manual I am using makes reference to timing the magneto an inch and a half past the pointer ? Does this sound right ? Any replies welcome. Quote Link to comment Share on other sites More sharing options...
td9inidaho Posted May 11 Share Posted May 11 12 hours ago, OLD 10-20 said: Trying to check the magneto timing on the WD-6 . Seems the first timing notch does not look like a notch , more of a cross pattern ? Then it has a clear to see notch on the crank pulley . Cranked it by hand to hear the impulse trip on # 1 and it trips well after the notch of the pulley , by just over an inch . Could the cross mark actually be DC ( dead center ) indication refering to the notch coming up ? The manual I am using makes reference to timing the magneto an inch and a half past the pointer ? Does this sound right ? Any replies welcome. Td,wd 6 should be the same motors I believe, this topic was covered pretty extensively in the construction side here, "when tdc isn't tdc on a td-6. It might give you your information you are looking for, I know those cranks have 2 marks, one for setting up the injection pump, the other tdc. If I remember correctly 🤔. Been ages since I rebuilt my 9. Good luck Mark Quote Link to comment Share on other sites More sharing options...
OLD 10-20 Posted May 12 Author Share Posted May 12 Think I found the article your talking about . Good info there . And I never looked past the TDC notch for another possible (M) magneto marking . Checking it out. Quote Link to comment Share on other sites More sharing options...
rustred Posted May 13 Share Posted May 13 On 5/10/2022 at 8:02 PM, OLD 10-20 said: Trying to check the magneto timing on the WD-6 . Seems the first timing notch does not look like a notch , more of a cross pattern ? Then it has a clear to see notch on the crank pulley . Cranked it by hand to hear the impulse trip on # 1 and it trips well after the notch of the pulley , by just over an inch . Could the cross mark actually be DC ( dead center ) indication refering to the notch coming up ? The manual I am using makes reference to timing the magneto an inch and a half past the pointer ? Does this sound right ? Any replies welcome. TDC can be found by sticking a straw in the #1 plug hole and rocking the engine in the centre of TDC , that will point you to the correct mark. Quote Link to comment Share on other sites More sharing options...
