ole 815 Posted May 11, 2022 Share Posted May 11, 2022 Last fall noticed when I tried to fold disk wing, quit working. Figured hose coupler or something. #3 remote Fast forward till today. (10th season with this tractor planter combo)#3 Can't get enough flow to run bulk fill fan on 1250 planter. Need 3000 rpm, will only do 2400rpm flow knob adjusted full flow. For some reason won't work to have that on #1 to run bulk fill. When you do it won't let #2 raise planter. Got it to work with bulk fill #2 Planter raise #1 Am I right thinking #3 has an issue in remote valve under cab? Quote Link to comment Share on other sites More sharing options...
756puller Posted May 11, 2022 Share Posted May 11, 2022 Need to stick a 5000 pound gauge in #1 extend coupler to check high pressure so see what max pump pressure is. Quote Link to comment Share on other sites More sharing options...
Dan Robinson Posted May 11, 2022 Share Posted May 11, 2022 @SDman @Maynard Quote Link to comment Share on other sites More sharing options...
SDman Posted May 11, 2022 Share Posted May 11, 2022 Max. flow requirements for 1250 planter bulk fill is 13GPM....Classic Magnums should be able to flow 22GPM out one remote. My first thought would be a broken, damaged flow control spring in #3 remote. Using #1 remote on bulk fill is a no-no. The tractor's flow control is wide open, the planter's electronics/hydraulic valving determine the amount of oil needed. This, in effect, means that the #1 remote is never fully satisfied, so no oil goes on down to the #2/#3 remotes. Quote Link to comment Share on other sites More sharing options...
ole 815 Posted May 11, 2022 Author Share Posted May 11, 2022 Thanks for the replies. I hope I don't lose another remote. I will update when I get time to work on it. Ground is shaping up fast. Planters are rolling! Quote Link to comment Share on other sites More sharing options...
