Cormick Willem Posted May 7 Share Posted May 7 For my restauration project with a Cormick WD 9 I need a bull pion cage. the mine is broken. Who can help me with that part. i woul like to hear. 1 Quote Link to comment Share on other sites More sharing options...
mmi Posted May 7 Share Posted May 7 common problem when removing with b gear still in or cross the # forward expect an m would work Quote Link to comment Share on other sites More sharing options...
rustred Posted May 9 Share Posted May 9 Shania Twain would tell you , you gone and done it! remove bull gear first. Quote Link to comment Share on other sites More sharing options...
FarmallFan Posted May 9 Share Posted May 9 I think this is what you are looking for? https://www.robertstractor.com/Farmall-McCormick-W9-Bull-Pinion-Carrier_p_7437.html Quote Link to comment Share on other sites More sharing options...
Cormick Willem Posted May 9 Author Share Posted May 9 Yes, that is indeed the part I need. At this moment i try to get the part in the Netherlands. If it is not I order it by Roberts. Tanks👍🏻 Quote Link to comment Share on other sites More sharing options...
mmi Posted May 9 Share Posted May 9 fiat pulled ALL the old # and NLA at stealer. looking for some old books,,......either H or M would be a good start,even if a new # Quote Link to comment Share on other sites More sharing options...
mmi Posted May 10 Share Posted May 10 spic spl wu etc, all either too new or too old ,discontinued along with 8854x there has to be more details as they would have had replacements into the '70s repair or modified M ,before shipping Ih was cheap std part modified for specific reason cant see if 7 = 5 bg sm st218a/227b 2 = 6 cage 357032-r1 + 1 357036-r11 9 = 12 brg lg st283 8 =11 shaft 357031-r11 and this would have the long drive end https://www.google.com/search?client=firefox-b-1&q=ih+wd+9+pinion+carrier&oq=ih+wd+9+pinion+carrier&aqs=heirloom-srp.. Quote Link to comment Share on other sites More sharing options...
jeeper61 Posted May 10 Share Posted May 10 On 5/9/2022 at 8:49 AM, FarmallFan said: I think this is what you are looking for? https://www.robertstractor.com/Farmall-McCormick-W9-Bull-Pinion-Carrier_p_7437.html Been there a couple of times Neat old yard in Morning-Sun, OH Quote Link to comment Share on other sites More sharing options...
Cormick Willem Posted May 12 Author Share Posted May 12 Thanks all for looking. A company in the Netherlands with a lot of contact in the US has found the part for me and can ship it to the netherlands. So i can go on with the WD 9 Quote Link to comment Share on other sites More sharing options...
KWRB Posted May 27 Share Posted May 27 Make sure to recheck gear contact patterns. There's no guarantee that the shims needed for the new cage will match what you had for the old one. Quote Link to comment Share on other sites More sharing options...
Cormick Willem Posted May 27 Author Share Posted May 27 7 hours ago, KWRB said: Make sure to recheck gear contact patterns. There's no guarantee that the shims needed for the new cage will match what you had for the old one. Thanks for your advice. I will check it. Quote Link to comment Share on other sites More sharing options...
