mjhettler Posted May 3 Share Posted May 3 Anyone know the procedure or have advice to remove and replace the cluster drive sprocket? Quote Link to comment Share on other sites More sharing options...
mjhettler Posted May 3 Author Share Posted May 3 I’m referring to the cluster of gears in the center of this photo (25) Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted May 3 Share Posted May 3 Might try over on HEF Quote Link to comment Share on other sites More sharing options...
CIHTECH Posted May 3 Share Posted May 3 Remove both axle groups, so you can remove the chains. Then pull shaft and remove cluster sprocket thru back access cover. 1 Quote Link to comment Share on other sites More sharing options...
mjhettler Posted May 3 Author Share Posted May 3 Thanks CIH Tech... I appreciate the advice and understand your recommendation! Quote Link to comment Share on other sites More sharing options...
ihrondiesel Posted May 3 Share Posted May 3 Do you have the cab rolled ahead? I worked on them for a few years before I figured that out, definitely makes life easier. Cluster sprocket isn’t a bad job but usually a dirty one. @CIHTECH nailed it. Quote Link to comment Share on other sites More sharing options...
bpatterson Posted May 3 Share Posted May 3 I agree with cih not hard to do at all I worked for a case construction dealer for 17 years as a mechanic I think those are the easiest machines to work on there is I can have the engine and pump out in a day easy I love them there simple and tough Quote Link to comment Share on other sites More sharing options...
mjhettler Posted May 3 Author Share Posted May 3 yeah, the 1845c has been a great machine on the farm. quite reliable and able to work on it without calling in a tech. Quote Link to comment Share on other sites More sharing options...
