TD7E D239 fuel pump timing
I am trying to set the static timing of the fuel pump on my TD7E with the D239 engine so that I can remove the fuel pump to remove/replace a broken mounting stud. The service manual that I have does not give me the number on the pump gear associated with the TD7E, it only gives me the numbers for agricultural equipment. Can someone provide me the correct number that I need to use? Thanks in advance
I will check my manual tomorrow, ours is a G and has a 4B but my manual covers the E
3 hours ago, Mark57 said:
What manual did that information come from, I could not find anything like that in the manual that I have for the D239 engine
The info is from an engine diagnostic manual from early 80's that covered all the IH engines used in Construction applications back then.
Manual # - ISS-1526-5.  Good luck with your project
Dennis
