MinnesotaFarmall Posted April 21, 2022 Share Posted April 21, 2022 Does anyone know without a doubt, no b.s. factual who made the third members for them? Seems it is a gm axle, but a montage of other parts. Quote Link to comment Share on other sites More sharing options...
bitty Posted April 21, 2022 Share Posted April 21, 2022 @Ed Leaman might have an idea who did 1 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted April 22, 2022 Author Share Posted April 22, 2022 Seems like they used a combination of their own proprietary parts, plus over the counter parts. Numbers off of the ring gears I have come back to nothing over the counter. Google, parts books, etc do not have matching numbers. How many ring and pinion ratios we're available? Were the transfer cases available in different gearing? Does anyone make gears for the transfer cases? Quote Link to comment Share on other sites More sharing options...
brewcrew Posted April 22, 2022 Share Posted April 22, 2022 Twenty years ago Trac Four (I believe they were the remnants of the original Elwood) could get basically anything you needed, but the transfer case parts were machined individually. And priced like a one-off part of course. It’s been a long time since I’ve heard of anyone doing business with Trac Four, so I doubt they are still in business. As much as I love an Elwood MFD axle, I wouldn’t want to farm with one anymore. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted April 22, 2022 Share Posted April 22, 2022 Haven't checked lately but the IH parts books had all the gear tooth counts for the transfer cases on the old system. As I recall there were different ratios for 15XX tractors and 14-under tractors. CNH did restore SOME of the NLA parts so maybe they're there. Quote Link to comment Share on other sites More sharing options...
GaryK Posted April 22, 2022 Share Posted April 22, 2022 Quick internet search shows this: All Mini Tractor Parts You Are Looking For | TracPartz TracPartz is 100% independent and can therefore deliver the highest quality for the best price. Our certified suppliers supply OEM quality parts with which we guarantee a long life! Mini tractor parts for all brands. Mini tractor parts for all well-known Japanese brands can be found at TracPartz in our webshop. The range of mini tractor parts knows no limits, from filterset to head gasket. TracPartz supplies both private individuals and mechanization companies. https://www.tracpartz.com Was this helpful? Trac 4 Inc 102 S Water St, Wilmington, IL 60481 - YP.com https://www.yellowpages.com/wilmington-il/mip/trac-4-inc-2406785 Tractor Equipment Trac 4 Inc Trac 4 Inc (815) 476-5538 102 S Water St Wilmington, IL 60481 Map & Directions Tractor Equipment & Parts Be the first to review! Add Hours 39 YEARS IN BUSINESS Add Website Suggest an Edit Is this your business? Customize this page. Claim this business More Info Gallery Reviews Hours Elwood · Braidwood · Hay · Coal City · Fish Hatcheries · Horse Trailers Quote Link to comment Share on other sites More sharing options...
jass1660 Posted April 22, 2022 Share Posted April 22, 2022 Can’t imagine Trac4 is still open. I was there in the early ‘90’s to get some parts and they hardly had any business then and they weren’t exactly young in age. Quote Link to comment Share on other sites More sharing options...
jnbru Posted April 22, 2022 Share Posted April 22, 2022 I was told the Ring and Pinion are an old GM pattern that was discontinued the only aftermarket company who made them when out of business years ago. When I finial tracked a set down it cost me $2500 used. I the outside pinion bearing are also in limited supply. They are one directional... that's what killed the ring and pinion in my axle. That bearing set me back around $270 new. These are 10 year old prices now. I still have a used bearing but it loose. 1 1 Quote Link to comment Share on other sites More sharing options...
DR.EVIL Posted April 22, 2022 Share Posted April 22, 2022 When ever I talked to anyone at Elwood about axles, they ALWAYS said everything from hub to hub and out to the drive yoke on the input pinion came from SPICER in Minnesota. Only person I ever knew at Spricer was my old Boss at FARMALL got his picture on the cover of Purchasing Magazine about 1990 being Purchasing Manager at that Spicer plant after the Farmall plant closed. Quote Link to comment Share on other sites More sharing options...
Torque Posted April 23, 2022 Share Posted April 23, 2022 The center section is an Eaton H110. I do not know who made them, GM used them in army trucks from about 1939 on and in commercial 1 1/2 ton trucks. Up to 1979 they were still used in some motor home chassis. Army trucks were 6.17 or 6.72 ratio, I think Elwood used a commercial truck ratio. The steering knuckles are army truck and the planetaries were designed and built by Spicer and adapted (by them I assume) to the army truck axle. The army truck always used Bendix steering joints but the Elwood (at least the one I had apart) had the much improved Rzeppa joints, may have been part of the Spicer modification. 1 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted April 23, 2022 Author Share Posted April 23, 2022 The ring and pinion I have in ours is a 4.88, that's where a lot of confusion came from when I went to look for parts. Seems everyone I talked to said that there are no options available for a 4.88. I'd be willing to bet that is what took mine out. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted April 26, 2022 Author Share Posted April 26, 2022 Just adjusted backlash on another mfwd of ours and it is a 5.43 ratio. I'm thinking that's what our 1086 should have instead of a 4.88. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted April 26, 2022 Author Share Posted April 26, 2022 On 4/22/2022 at 2:00 PM, jnbru said: I was told the Ring and Pinion are an old GM pattern that was discontinued the only aftermarket company who made them when out of business years ago. When I finial tracked a set down it cost me $2500 used. I the outside pinion bearing are also in limited supply. They are one directional... that's what killed the ring and pinion in my axle. That bearing set me back around $270 new. These are 10 year old prices now. I still have a used bearing but it loose. Got any more pics? Quote Link to comment Share on other sites More sharing options...
R190 Posted April 29, 2022 Share Posted April 29, 2022 Elwood had two different series axles back in the day the Elwood axle as formerly used by IH which was mostly Spicer and their own components and the T-4 which we were told had a GM carrier and unique wheel hubs. There was about $4000.00 difference in dealer cost back in the mid 80s between the two. I misplaced my manuals and price book from back then so I have very little more I can add. 1 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted May 11, 2022 Author Share Posted May 11, 2022 Found this in our original owners manual for our 1586, thought it was neat. 6 Quote Link to comment Share on other sites More sharing options...
