redpower123 Posted April 21, 2022 Share Posted April 21, 2022 I was checking my fan belts and one is a little bit looser than the other,I just got them last year and they were a matching set zip tied together, and I was wondering how tight is too tight. Thanks Quote Link to comment Share on other sites More sharing options...
Red Tech Posted April 21, 2022 Share Posted April 21, 2022 I would guess that the alternator is cocked in the mount. Quote Link to comment Share on other sites More sharing options...
stronger800 Posted April 21, 2022 Share Posted April 21, 2022 Or the belts are just crappy. I know the last few matched sets I have gotten, for a 1066/1466 they are not matched very well. So one of them always ends up a little bit loose, because that’s better than having the other one a little bit too tight in my opinion. 10 years ago they were always perfectly matched. Quote Link to comment Share on other sites More sharing options...
cedar farm Posted April 21, 2022 Share Posted April 21, 2022 IH or aftermarket belts? Quote Link to comment Share on other sites More sharing options...
Timothy56 Posted April 21, 2022 Share Posted April 21, 2022 Can a banded or web belt be used for fan belts? Or why not? Had that problem on a pump jack. Went to a banded belt and that works a lot better. Quote Link to comment Share on other sites More sharing options...
jass1660 Posted April 21, 2022 Share Posted April 21, 2022 One groove on pulley may be worn more. 2 Quote Link to comment Share on other sites More sharing options...
hardtail Posted April 21, 2022 Share Posted April 21, 2022 8 hours ago, Timothy56 said: Can a banded or web belt be used for fan belts? Or why not? Had that problem on a pump jack. Went to a banded belt and that works a lot better. Don't usually see them in engine applications, possibly because mismatch of grooves per accessory, belt failure leaves you with nothing to limp back, your sheaves should all be in great condition so it sits in the proper position, wouldn't work with adjustable pulleys that are opened up, not sure they are available for this application and there could be a reason why, I agree matched sets aren't that close at times anymore Quote Link to comment Share on other sites More sharing options...
jass1660 Posted April 21, 2022 Share Posted April 21, 2022 Unless you can get serpentine style belts and pulleys like on Navistar truck engines Quote Link to comment Share on other sites More sharing options...
stronger800 Posted April 21, 2022 Share Posted April 21, 2022 I have been buying matched sets of IH belts from the dealer whenever I needed them as long as I can remember, and I have not been happy with the last two sets. I’ve even tried swapping them front to back to see if one fit on 1/2 of the pulley better and the size difference was still apparent Quote Link to comment Share on other sites More sharing options...
catman13 Posted April 21, 2022 Share Posted April 21, 2022 check your alternator and fan pully for wear, most of these belts are cheap chinese stuff and somebody just throws 2 belts together and calls them matched Quote Link to comment Share on other sites More sharing options...
stronger800 Posted April 22, 2022 Share Posted April 22, 2022 Yea. the Numbers on them match. Quote Link to comment Share on other sites More sharing options...
acem Posted April 22, 2022 Share Posted April 22, 2022 I have a few engines I can't run two belts on. The water pump/fan pulley is worn uneven. I need to replace them but they are pricey. Quote Link to comment Share on other sites More sharing options...
