jong1821 Posted April 19, 2022 Share Posted April 19, 2022 Anyone know a way to reconnect the orafice screen to the orafice in a safety/ regulator? I'm working on my 460 utility. Removed the orafice to check the screen. The screen crushed and separated. A new one is around 200$. Not trying to spend that much. Quote Link to comment Share on other sites More sharing options...
jong1821 Posted April 19, 2022 Author Share Posted April 19, 2022 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted April 19, 2022 Share Posted April 19, 2022 Epoxy works. Reshape screen and get it to fit on shoulder. Apply epoxy. Doesn't take much. Flow is from screen to orifice. Quote Link to comment Share on other sites More sharing options...
Dan Robinson Posted April 19, 2022 Share Posted April 19, 2022 I did have alright luck soldering one back on. Didn't look super pretty but did get it stuck on. Quote Link to comment Share on other sites More sharing options...
hardtail Posted April 20, 2022 Share Posted April 20, 2022 Don't know if you have access to a lathe but you could cut a small groove and use some fine wire Quote Link to comment Share on other sites More sharing options...
Red Tech Posted April 20, 2022 Share Posted April 20, 2022 I cleaned off any bits of screen from the shoulder of the orifice. I reshaped the screen so it again fit on the shoulder. I then took it to a radiator shop to have it brazed / soldered? He did a perfect job! It looked like new. Quote Link to comment Share on other sites More sharing options...
