Redman66 Posted April 16 Share Posted April 16 Checking this new reliance head gasket for a 263. The old head gasket had perfectly round holes. This gasket has egg shaped holes. Parts counter said it’s correct. Is it? Quote Link to comment Share on other sites More sharing options...
tractorholic Posted April 16 Share Posted April 16 Mine didnt like that a few months ago. But I don't think it was reliance. I know the one we took out had round holes too Quote Link to comment Share on other sites More sharing options...
FarmerFixEmUp Posted April 16 Share Posted April 16 I have a new Fel Pro in the drawer and it has somewhat of an egg shape but not that much. Quote Link to comment Share on other sites More sharing options...
rustred Posted April 16 Share Posted April 16 i would not use it. , especially if old one has round fire rings. i dont see how that can seal. 1 Quote Link to comment Share on other sites More sharing options...
Maynard Posted April 17 Share Posted April 17 Put it against the head and see how it looks. 1 Quote Link to comment Share on other sites More sharing options...
560Dennis Posted April 18 Share Posted April 18 I’m not an expert head gasketer. But I question this? , the steel sealer ring in my opinion should seal the head to the sleeve. Again my opinion the pressure of combustion is going to go down the sleeve counter bore entering into the water jacket . Am I wrong? Also metal side of the head gasket goes down to block .graphite up . They tell me at Fel pro to use light coat of copper sealer on the metal side only. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted April 18 Share Posted April 18 Maynard has it. There are different combustion chamber shapes. Compare the gasket to the head. The round shape would do no good if there is no head compressing it. Quote Link to comment Share on other sites More sharing options...
R190 Posted April 18 Share Posted April 18 It looks good to me as others said compare it to the head I believe the early straight valve sixes used a rounder head gasket compared to a slant valve. Quote Link to comment Share on other sites More sharing options...
VacDaddyt Posted April 18 Share Posted April 18 Ok if the other head has a different shape for the gasket, then his fire crate domes need to fit up inside the head or there is a clearance issue there. I ran into this buying a used head which turned out to be from a 656 or 706. A lot going on there. Quote Link to comment Share on other sites More sharing options...
Redman66 Posted April 18 Author Share Posted April 18 After comparing this to the head, this appears to be the correct gasket. Thanks for the input. Here is a picture of the gasket on the head. 3 Quote Link to comment Share on other sites More sharing options...
Dan Robinson Posted April 19 Share Posted April 19 9 hours ago, 560Dennis said: I’m not an expert head gasketer. But I question this? , the steel sealer ring in my opinion should seal the head to the sleeve. Again my opinion the pressure of combustion is going to go down the sleeve counter bore entering into the water jacket . Am I wrong? Also metal side of the head gasket goes down to block .graphite up . They tell me at Fel pro to use light coat of copper sealer on the metal side only. These engines are dry sleeve, press fit sleeves. So they are not near the water jacket. 1 Quote Link to comment Share on other sites More sharing options...
hardtail Posted April 19 Share Posted April 19 Do you have a pic of the old gasket against the new Quote Link to comment Share on other sites More sharing options...
Redman66 Posted April 19 Author Share Posted April 19 No the old gasket was on the head when it went to the machine shop and is long gone now. Quote Link to comment Share on other sites More sharing options...
