AKwelder Posted April 14, 2022 Share Posted April 14, 2022 Local cat dealer, NC Machinery, had a truck driver leave the boom up on an excavator this winter, but he made it under the bridge. https://dot.alaska.gov/nreg/mitchellbridgestrike/#main_content there is talk that they will be held responsible for the cost of the repairs , and that could be expensive Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted April 14, 2022 Share Posted April 14, 2022 They’ll probably settle for whatever the insurance policy limit is even if that’s not enough to cover it. Which, if you’re in the trucking business the policy limit better be a large number. Quote Link to comment Share on other sites More sharing options...
AKwelder Posted April 14, 2022 Author Share Posted April 14, 2022 5 minutes ago, Dirt_Floor_Poor said: They’ll probably settle for whatever the insurance policy limit is even if that’s not enough to cover it. Which, if you’re in the trucking business the policy limit better be a large number. Hope your right. The dealer being a large multi state corporation isn’t going to help them much. Quote Link to comment Share on other sites More sharing options...
Big Bud guy Posted April 14, 2022 Share Posted April 14, 2022 That is not first time that has happened. My dealer had one of their truckers ram an air drill into an overpass. I know a farmer who ran an excavator into an overpass. He didn't lose the farm. Had insurance Quote Link to comment Share on other sites More sharing options...
AKwelder Posted April 14, 2022 Author Share Posted April 14, 2022 It appears they took out the entire bottom cord of the cement beams on about 6 of the beams. Maybe it’s repairable. Quote Link to comment Share on other sites More sharing options...
E160BHM Posted April 14, 2022 Share Posted April 14, 2022 Bridge strikes are not that uncommon. It seems that the smaller machines like a plumber’s backhoe loader that someone forgot to lower the stick or a small excavator loaded with the stick vertical. Usually totals the machine. We had a M318 come into the yard that had been loaded at an auction in Kansas and hit the bridge on US 65 under I80. It was a brokered load hauled by a “guy with a step deck” who loaded it with the stick vertical just like it had been parked in the yard. Again the machine was totalled. IRRC the bridge was no more that 14’ 6”” and had many battle scars. Quote Link to comment Share on other sites More sharing options...
brewcrew Posted April 14, 2022 Share Posted April 14, 2022 Tape measures are cheap. 3 Quote Link to comment Share on other sites More sharing options...
midnightman Posted April 14, 2022 Share Posted April 14, 2022 1 minute ago, brewcrew said: Tape measures are cheap. Unfortunately educating people to use them seems to be more expensive.😆 2 2 Quote Link to comment Share on other sites More sharing options...
Big Bud guy Posted April 14, 2022 Share Posted April 14, 2022 52 minutes ago, midnightman said: Unfortunately educating people to use them seems to be more expensive.😆 The farmer I mentioned in my previous post rented an excavator from the local JD construction dealer. Upon leaving the dealer he went down the highway to the nearest truck stop to fuel up. He pulled up to the pumps and the arm cleared the awning. On the other side of the pumps was a reefer truck. So he looked at the reefer and the excavator arm and both looked pretty similar in height so he thought he was good to go………..He wasn’t. Quote Link to comment Share on other sites More sharing options...
Cattech Posted April 14, 2022 Share Posted April 14, 2022 I've seen our DOT patch beams that had been hit but the damage wasn't as bad and usually only the outer beam. The bottoms of those I beams is under tension, not compression, so if the pre-stressed cables are not damaged, they shouldn't have lost much in integrity. While expensive, for a company of that size, even if they have to replace the whole bridge, the bill probably won't exceed their insurance deductible. Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted April 14, 2022 Share Posted April 14, 2022 16 hours ago, AKwelder said: Local cat dealer, NC Machinery, had a truck driver leave the boom up on an excavator this winter, but he made it under the bridge. https://dot.alaska.gov/nreg/mitchellbridgestrike/#main_content there is talk that they will be held responsible for the cost of the repairs , and that could be expensive That happens more often than you would think I would think they would have insurance for that but I have seen some owner operators go under from that. I have seen it here in Maine 5 or 6 times on I-95 Quote Link to comment Share on other sites More sharing options...
Dave Shepard Posted April 14, 2022 Share Posted April 14, 2022 I hired a roll back to move my Kubota backhoe. I told him it was 9'-6" with the boom pinned up. When I got to the jobsite the boom was down, the pin was in three pieces, and he was white as a sheet. Apparently the front of the truck cane off the ground when he hit the bridge. No damage to the bridge. Quote Link to comment Share on other sites More sharing options...
