TD6, D248 Engine needs help
like Hardtail says, ag tractors like Farmall MD or International WD6.
DWF
On 4/8/2022 at 1:07 AM, Papa Eli-53 said:
I have a 1951 IH TD6 Crawler with a D248 engine /3.875 Bore.
Need the following parts:
Pistons, Piston Ring set (std), Rod Bearings (std), Head gasket set, Oil Pan gasket.
Any idea where to find these parts???
Thanks for your help,
Papa Eli-53
Try here. Agkits | Tractor Parts, Tractor Manuals, Tractor & Truck Engine Kits - Search
I did... They don't have pistons /3.875 Bore; All their rebuilt kits come with a 4.0 Bore.
Would a 4.0 piston /sleeve fit into my (D-248) block????
It looks like lots of work to change the sleeves. However, I will change them if is the only way to get the new pistons....
Thanks so much for all the great help....
If you buy any parts use the ads in RPM and still ask alot of  questions  vs will fit and run a week china parts.
Many of the " complete" kits out there are SO bad "you" are responsible for sourcing the " not included " bearings
