450 clutch TA questions
forwhldrv
38 minutes ago, beekeep15 said:
could you explain the pump hanging off the belt pully. couple of gages mounted on it looks like . possable air compressor,   cant tell for sure pretty good idea what ever it is
Yes it is an air compressor from a Detroit it’s got a water cooled head and is fed oil from the pressure side of the motor oil and gravity back to the crankcase  it’s a neat conversation piece but if you run the tractor at any more than an idle the oil doesn’t return fast enough and leaks out the adapter from the belt pulley drive to the compressor
  • Replies 61
  • Created
  • Last Reply
7 hours ago, Matt Kirsch said:
That plow ain't got no wheels on it!
Fast Hitch, on a 650?
Yes it is the former owner put it on. It doesn’t make it any easier to get on
2 hours ago, DT Fan said:
That is a very cool plow-day combo. Always liked a 650, and the fast-hitch makes it that much better! Does it have working draft adjustment?
No draft control I try to set it olio at a depth  before hand and have a chain so I don’t go to deep. It’s a fun tractor to plow with this video is from a few years ago rolling right along for the camera
2 hours ago, forwhldrv said:
Here’s where I am with the 450 going to put some casters on the splitting legs to make it a little easier
I'd suggest straight wheels so it goes straight apart and back together easier
Maybe mixed up, but wonder if the 650 belonged to Wardner at one time.
