340 series literature/photos
mmi
Slowly making it thru some of the literature and started to list What we have.
Going to be a long list ,esp with photos ..... is there a thumb nail option on here?
Send me what you have and/or Corrections and I will add,(here) so this isnt 50 pages to go thru ,with 40 + models  to cover.
The 340 was not fully approved out ,so IH used a lot of excess 350 parts/tooling to save $$$,again to save R & D,it became the 404 thru 504
CREATION
PIC-316 9-10-58      RE:CEC -30 RELEASE OF I T-340
PIC-316-1 4-6-60    RE-FES ,RE CEC 156-1  T/TD-340 COLOR CHANGE TO 483 FEDERAL YELLOW  ,201/901 BY REQUEST
                                  CEC 156-2/163-9  NAMING AND IND HARD NOSE APPROVED (MELROSE)(WHOM HAS THE SERIAL/PRODUCT RPTS ?)
PIC-446 2-10-60     RE:TC-25 RELEASE OF IND 340/460 (HARD NOSE ONLY W/NAME)
PIC-465 4-8-60      RELEASE OF TD-340    MELROSE
PIC-478 5-31-60     RE: TC-30   COLOR/NAMES 240/340/460
               12-13-60    TC-62 ANNALISE OF OFFERING 340/460 GROVE
PIC-557 4-10-61      RE:TC-62    RELEASE OF I 340/460 "GROVE"
PIC-580 10-16-61     IH RED 201 RETIRED WITH "IMPROVED" 2150 STARTING WITH PROD. NOV.1  201 RETAINED FOR PARTS.
PIC-657  7-23-62      RE-T/TD-340 DELAY IN RE BADGING TO PAYLINE ,THIS WAS MODIFIED FOR LATE MODELS
  SERVICE
GSS-1015-O
GSS-1015-V SPECS
GSS-1032   TAD
GSS-1039   4CYL ENG
GSS-1051  BRAKES
GSS-1052
GSS-1060 TA
GSS-1065 FT AXLE/PS
GSS-1110   330 SPECS
GSS-1114    WAGNER BACKHOES
GSS-1132   D-166 FUEL ?
GSS-1231   C-135 SPECS
GSS-1256   T-340 CLUTCH
GSS-1257    T-340 TRANS
Image 1 - IH INTERNATIONAL 340 SERIES CRAWLER TRACTOR TRANSMISSION MANUAL
GSS-1258    T-340  HYD
Image 1 - International Harvester 340 Crawler Service Manual GSS-1258 Hydraulic Equipment
GSS-1259    T-340   TA
GSS-1260     T-340  DIFF FL
GSS-1261      T-340  CHS TRACK
GSS-1262       T-340  IPTO P
Image 1 - IH Blue Ribbon Service T340 TD340 GSS-1262 Independent PTO (Planetary) ORIGINAL
GSS-1263      T-340  COOLING
Image 1 - IH INTERNATIONAL 340 SERIES TRACTOR COOLING SYSTEM MANUAL
GSS-1264       T-340  F & R
Image 1 - IH International Farmall 340 460 full forward reverse drive service manual
GSS-1270       D-166
Image 1 - IH Farmall International 340 Diesel Engine D-166 Service Manual
GSS-1271 A/B/C  D-166 FUEL
Image 1 - Farmall International 340 Diesel Fuel System and Injection Pump Service Manual
GSS-1272    SPEC
Image 1 - IH Farmall Mccormick International T340 TD340 Crawler Specifications Manual
GSS-1282 A/B/C/D  IPTO C
GSS-1283   WAGNER  BH LDRS
GSS-1295     C-135
GSS-1295-C    C-135
GSS-1295/J  C-135
GSS-1298   SPEC  340-460 GROVE
Image 1 - 1961 INTERNATIONAL HARVESTER 340 460 GROVE ORCHARD TRACTOR SPECIFICATIONS MANUAL
GSS-1304   HARLO
GSS-1309   CARB SPECS
GSS-1318   DRAFT 404
GSS-1319   SPECS 404- 504
GSS-1322   D-188
GSS-1322-F    D-188
GSS-1327 404 PTO
GSS-1330  340/404/504 TRANS
GSS-1331-B TRANS  240-404
GSS-1337-C  PS 404/504
GSS-1339  2000 LDR
GSS-1357   TEST HYD
GSS-1360        404 STEER/AXLE
GSS-1371-K   TEST HYD 3121/31/41
GSS-1403    TB SENSOR 404/504
ISS-1039-1   4CYL GAS
ISS-1044
Image 1 - IH Farmall Mccormick International T340 Crawler Chassis Service Manual
ISS-1550      3121/31/41 BH
OWNERS
Image 1 - IH INTERNATIONAL 340,460 TRACTOR THREE POINT HITCH MANUAL
Image 1 - IH INTERNATIONAL 240,340,460 TRACTOR HYDRA TOUCH SYSTEM MANUAL
Image 1 - IH INTERNATIONAL 340, 460 TRACTOR TWO POINT FAST HITCH MANUAL
Image 1 - IH INTERNATIONAL 340, 460 TRACTOR TEL-A-DEPTH CONVERSION MANUAL
Image 1 - IH INTERNATIONAL 340 TRACTOR THREE-POINT FAST HITCH MANUAL
Image 1 - IH INTERNATIONAL 340, 460 TRACTOR HYDRAULIC POWER STEERING MANUAL
Image 1 - IH INTERNATIONAL 340 TRACTOR THREE POINT FAST HITCH MANUAL
Image 1 - IH INTERNATIONAL 340, 460 TRACTOR THREE POINT HITCH MANUAL
Image 1 - Farmall 240 340 460 560 remote control adapter units operator install manual
Image 1 - IH International Farmall Cub 140 240 340 Horn Installing Instructions Manual
OM-1011531   58   460 RUNNER PLANTER FOR 3/4 SERIES
Image 1 - IH McCormick 460 Runner Planter for Farmall 300 340 350 400 450 Operators Manual
OPM-1011966R3     IH/DROTT 3040 LDR
OM-1014015       57           330
OM-1014185  F/I 340
Image 1 - IH Farmall Mccormick International 340 Owners Manual
OM- 101           340 GROVE
OM-1014203  340 (IND?)
OM-1014261-R1     HARLO FL REAR
OM-1014265-R1   61  HARLO FL 340-460
OM-1014284  2404 IND
OM-1014285 2504 IND
OM-1014655    UC-135
OM-1014727       59     340 G6 GRADER
OM-1014796        61        T-340
OM-1014950          62      T-340A
OM-1014951        62     TD-340A
OM-1019291   T-340A
OM-1019757   3120/30/40 BH
OM-1019837  2000 LDR
OM-1082594  404
OPM-1083443    9-71   3121/31/41 BH
OM-1085057  UD-135-B/UC-153
OM-1085813   TD-340
OM/PM ?           CUB -340
Image 1 - IH Farmall Mccormick International Cub 140 240 340 Preventive Maintenance Manual
OM/PM   ?         340D-460D
Image 1 - International McCormic Maintenance Manual FARMALL 340 460 560 660 Diesel Tractor
PARTS
 BH         3120/30/40  WAG 65T
IND-2      HARLO
LDR DROTT -340-K3
Image 1 - INTERNATIONAL HARVESTER T-340 CRAWLER TRACTOR DROTT 340K3 SKID SHOVEL MANUAL
LDR IH 3040
LDR WAG  465
LDR-1       2000 LDR
Image 1 - International Farmall Loader Tractor T-340 T340 3040 A Parts Catalog Manual IH
PC-ENG-1   4cyl gas
PC-ENG-4  D-188
PC-IND-2    HARLO
PC-TE 21 0/A/B/C/  340G6
Image 1 - IH International T340 TD 340 Crawler Tractors Bullgrader 340G6H Parts Catalog
PC-PT -H     3XXX IH BACKHOES
PU-56        UC-135
PU-66B     UD-135B/ UC-153
TC-71 0/A  330/340
Image 1 - International 330 340 Utility and Farmall 340 Utility Tractors Parts Catalog
TC-77 O/A/B/C/D/ T-340/TD340/A
Image 1 - IH International T-340 Tractor Crawler Parts Manual Book list catalog TC-77 1960
Image 1 - OEM International Harvester TC-77A T-340 Crawler Tractor Parts Catalog 1961
Image 1 - IH Farmall Mccormick International T340 TD340 Crawler Parts Manual
Image 1 - International T-340 Series TD-340 Crawler Tractors Parts Catalog Manual SKU-F
Image 1 - 1967 International Harvester TC-77D T-340 TD-340 Crawler Tractors Parts Catalog
TC-86   404
TC-88 504/2504
SALES........
Image 1 - Anderson Dozer specification sheet brochure for International T-340 T-5 tractor
Image 1 - IH International Harvester Danco Heavy-Duty Rotary Mower Brochure CUB 340 Lo-Boy
Image 1 - IH Farmall International 340 3 Plow 4 Row Utility Tractor Dealer Brochure Mailer
A-950                      T-340/DROTT 4-1 ACC
CC-IL-13                   I/F 340 LUBE CHART  (62)
Image 1 - International Farmall 340 tractor lubrication service guide chart
CR-1-M             62     PARTS ACCS
CR-1-N1            63    PARTS ACCS
CR-3-P2             64     PARTS ACCS
CR-1001-L          61    IND
CR-1001-M1       62   IND
CR-1184-I           59      340U SPECS
CR-1196-G                 340 LDR
CR-1196-K        60   T-340 WAGNER 465
International Harvester Wagner Backhoe & Loader T-340 Crawler Dealer's Brochure
Image 1 - IH Power Loaders Farmall & International Tractors Brochure 240 340 460 560 B-275
CR-1197-L         61    IND CUB-660
CR-1207-I               340
CR-1216-L      61     240 IND
CR-1221-L   340 -460 IND
CF-1273-      59   T-340  SPECS
CR-1283-I      59     IND CUB -460
Image 5 - IH International Utility Industrial Tractors Brochure 140 240 340 460 560 Cub
CR-1303-L    61      340 IND
CR-1307-I    59     340U SPECS
CR-1320-L     58     F-340
Image 1 - MCCORMICK FARMALL INTERNATIONAL IH 340 TRACTOR c 1950 sales brochure  CR-1320-L
CR-1330-I    59     T-340 DROTT 4-1
CR-1336-H   58    F-340
Image 1 - MCCORMICK FARMALL INTERNATIONAL IH 340 TRACTOR c 1950 sales brochure  CR-1336-H
CR-1337-H      58     340U
CR-1350-L     61      340 FL
CR-1356-I      59    T-340 DROTT
CR-1369-K     LOADERS  BACKHOES
CR-1370-P      64   IND
CR-1392-M     62    NEW 404
Image 1 - International McCormick Farmall Row-Crop & International 404 Utility Brochure
Image 1 - International McCormick Farmall 404 Row-Crop Tractor Sales Brochure IH Leaflet
CR-1393-M      62     NEW F 504
Image 1 - International McCormick Farmall Row-Crop & International 504 Utility Brochure
CF-1394-M      62     NEW 504
CR-1420-M       62    NEW 2404
CR-1447-M         62      F I 504
CR-1447-N1         63     F I 504
CR-1454-K      60   T-340 HYD GRADER
CR-1458-P3    64    FULL LINE
CR-1478K  (9-1) T-340
CR-1578-I         59    T-340 HYD GRADER
CR-1711-M        62    T-340 BLADES  G6 600 700 ETC
CR-1716-M         59    T-340
CR-1718-M          62    T-TD340 A
CR-1761-M    62   T-340 HARLO
CR-1784-M      62     2404 IND
CR-1786-M      62      2504 SPEC
CR-1862-M      62   T-340
CR-1863-M       62  T-340 DROTT 4-1
CR-2140-N        63    504 FH
CR-2373-N1               T-340 RBR SHOES
CR-5081-M                  TRACKS
CR-5265-P         64    IND PARTS
K-900                59     T-340   DROTT T-RIFFIC
Image 1 - DROTT 4 in 1 Bucket Blade for IH T-340 Crawler Tractor Brochure Loader Bulldozer
SK-45             61   T-340  700 ANGLE DOZER
STATS
I-330-GU  58     4262 LAST (4763)
F-340-G    58-63   58 (2104)  #501-7711  (7211)-586 + - 59 1ST (2501) 60 (5075)
F-340-G      CR/H        '61 (55)
F-340-D    59-63   586
F-340-D      CR/H        '61 (5)
I-340-GU     58-63   58 (2145) #501-12,338 (11837)- 590 + -   ,59 1ST (2428) 60 1ST (5281) 61 T(2368)
I-340-DU    59-63   547        61 (509)
I-340-G-HC
I-340-D-HC
I-340-G IND            310 + -   Must include "FACTORY" installed , F & R,HD axle,complete hard nose pkg....MORE ?
I-340-G IND PARSONS
I-340-D IND               7 +-
I-340-D IND PARSONS
I-340-G GROVE        61 (10)
I-340-D GROVE          36        61 (76)
I-340-LP  ?
I-340-G  HARLO
I-340-G  AUBURN
HT-340                                 2
T/TD-340        59-62   (4094) (775)
T/TD-340-A     62-65   (2220)(1666)          (8755) +-
T-340   R/W-FARM  DB/A-O/PTO 3PT   , <1500
T-340    R/W  FARM/WAGNER 465
T-340 R/W/Y  TOOLBAR/BLADE
T-340 R/W/Y  PLAIN OR WITH DEALER OPTIONS 500 BLADE ETC
T-340-LOGGER DROTT CLAW + WINCH
 T-340 USDA
T-340 HIGH   NE
T-340 WIDE  NE
T-340A                       62-65      (2220)(6314)
T-340    IH 6WY
T-340A RAILROAD/WAREHOUSE
TD-340                    60-62         (775)
TD-340A                  62-65         (1666)(2441)
TD-340-A 6WY MANUAL TOOL BAR
T/TD-340A G6  6 W BLADE
T-340A HARLO
TD-340-A HARLO
fInternational_td340_crawler_forklift__35_5d1c26e8dfad6.jpg.2d5406b4a381afcdf0904c8eaa20c9e7.jpg
TD-340 PIPELAYER
T/TD-340-A DROTT + WEIGHTS
T/TD-340 DROTT/IH + SCARRIFIER
T/TD-340A -IH 3040
TD-340A-IH + 3XXX
TD-340 WAGNER 465
I-404
F-404
I-2404
I-504
I-504-HC
F-504 SHORT
F-504 LONG
F-504 CR/H
I-2504
TOYS
Image 1 - SPEC CAST 1/16 INTERNATIONAL HARVESTER IH FARMALL 340 DIESEL SE  TRACTOR
Image 1 - SpecCast IH Farmall 340 Gas WF Tractor 1:16 Scale Diecast Highly Detailed NEW
Image 1 - SpecCast Vintage Farmall 340 Gas Narrow Front Tractor with #31 rear Mount Mower
Image 1 - Ertl 1/16 International T-340 Crawler.  Stk#4734
Image 1 - ERTL  Case International T-340  Crawler 1:16 in box
Image 1 - NIB ERTL 1/16 INTERNATIONAL INDUSTRIAL YELLOW T-340 DOZER W/BULLGRADER BLADE
Image 1 - Vintage Ertl 4380 International T340 with Bullgrader Crawler Tractor-DieCast1:16
Image 1 - Ertl Case International T-340 Yellow Crawler Tractor 1:16 diecast metal Toy MIB
SUB NOTES
F-135D FRENCH BUILT 2 CYL DSL= USA 130
BTD640 DONCASTER = CHEAP 40HP BTD6
Just to clarify,  are you asking for literature or individual tractor information? I have a 340 and a couple pieces of literature for it (I think) and happy to share,  just want to be sure what you need.
Mac
Trying to share /collaborate/confirm/add on the info, we have before it gets lost.
Beyond a stack of notes and box s of files, books, photos etc.....A place to list it all out,curate ,and not have to also donate $$$$, to then still have it locked away in some vault ,on $$$ pay per view.
GC are not/no longer,interested past their phones ,and the daily PC mandated stress of life.
I may wait 6 months to get 5 ( very intense forced ,but NEVER devoid of PLAYING !!! on the ^&*(^&* PHONE), minutes for a yes/no do you have any interest in x ?
Can you make a decision.... Toss/ keep/ take to YOUR home.....? Again today after 3 minutes ,90% went un handle ed.
The 340 linage is the most diverse varied/optioned and advertised.
Will/would take time,but can place at least 1 photo with each entry above.
others may have a better/different  example/photos, or the missing bits and not know it. Melrose records leave a BIG hole.
A. without thumb nails this is going to be very long.
B. if every one posts as add ons it will be 10x longer and cumbersome to fact check and search/view.
C. RPM/SALLY has a lot of serial # data that can be re applied in different ways.
D. 15% of differences occur within after x serial # /date. ie: 4 different dash s ,but need photos/ books a or d etc
On 4/1/2022 at 7:24 PM, MacAR said:
Let me snap a few pictures and I'll PM them to you. That way you can organize them how you like.
Mac
will organize by how you/others like under proper heading,9-10-60  +- 3
Maybe Jeff can offer what the 17 + badges SHOULD look like
then we need 6+ dash including the short grey
Here's a photo of the dash on #7772:
Naturally, it isn't original. The tach was missing and I patched the hole and repainted the entire dash when I installed the new gauges. Will take a photo of the emblems first chance I get, likely this weekend when I have it out.
Mac
  • 6 months later...
