Sparky Posted March 25 Share Posted March 25 If I'm looking these up correctly, the part number is 536648R1 and it takes eight of them at $33.80 each... Now, I'm all for using the dealer for parts like this, but this price seems a little much for a bushing, even if they will last 50 years. I have a 1066 that has bushings that are just completely done for. I figure a salvage yard will laugh at me if I asked for them. Anybody have a good source or a better idea? Thanks Travis Quote Link to comment Share on other sites More sharing options...
acem Posted March 25 Share Posted March 25 I've made similar pieces from rubber washers and hose. I made the washers from an old inner tube. It's alot of work. I cut big washers out of an old mud flap to repair the cab mounts on my 4366. Thx-Ace Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted March 25 Share Posted March 25 I "built" my on platform isomount bushings out of rubber sleeve and rubber disks I bought from McMaster-Carr. They also have rubber mounted on washers that work for hoods, or as part of the isomounts. Takes a bit to piece together some stuff, but you get 50 or 100 for a few $. 1 Quote Link to comment Share on other sites More sharing options...
Sparky Posted March 25 Author Share Posted March 25 1 hour ago, Jeff-C-IL said: I "built" my on platform isomount bushings out of rubber sleeve and rubber disks I bought from McMaster-Carr. They also have rubber mounted on washers that work for hoods, or as part of the isomounts. Takes a bit to piece together some stuff, but you get 50 or 100 for a few $. The platform isomounts are a whole lot easier to make compared to these, I believe. Travis Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted March 25 Share Posted March 25 I do believe you! Just thought the same approach might work, finding pieces to stack to create a similar item. I spent DAYS trying to find a "vibration Isolator" that would replace the floorboard mounts, or be modified to do so, and found nothing! Quote Link to comment Share on other sites More sharing options...
hippy5488 Posted March 25 Share Posted March 25 look at mcmaster carr. have got the same design from them just dont know about the right size. however that seem more reasonable than 1990625c1 price. $69 a piece. the cable ends for magnum hyd. cables. blew my mind Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted March 26 Share Posted March 26 Have any pics of them you can show ? Quote Link to comment Share on other sites More sharing options...
rrr4quality Posted March 26 Share Posted March 26 I searched the part number online to see if I could add an image but no luck. Appears to be a sleeve type bushing. Maybe buy one and search with correct measurements. Quote Link to comment Share on other sites More sharing options...
andrewn269 Posted March 26 Share Posted March 26 I would think McMaster Carr found these for utility tractors 90$ each thru CNH like 9$ from mcmaster only difference was it was square with 4 mounting holes but the 2 on angle where the correct distance Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted March 26 Share Posted March 26 The 1400 series combines used rubber mounts under the electro hydraulic block I have gotten them recently Quote Link to comment Share on other sites More sharing options...
Doc Egor Posted March 26 Share Posted March 26 Try Lord MFG out of Erie PA. They made the radiator vibration mounts originally (as well as other mounts) and I've bought the original design parts from them for a fraction of the cost. I believe they are a part of Parker now, so things might have changed....but it would be worth a phone call and maybe sending them a picture or drawing with the dimensions. 1 1 Quote Link to comment Share on other sites More sharing options...
andrewn269 Posted March 26 Share Posted March 26 Maybe this? https://www.mcmaster.com/isolation-mounts/easy-to-install-vibration-damping-mounts-with-unthreaded-hole/ just from memory of way it looks bet this one is close https://www.mcmaster.com/6309K67/ need measurements of hole and thickness of material https://www.aircraftspruce.com/catalog/pdf/15-05688.pdf https://www.zoro.com/zoro-select-flr-mnt-2-pc-cntr-bnded-vibration-isltr-dimension-c-34-in-2npg8/i/G2102484/?utm_source=google&utm_medium=surfaces&utm_campaign=shopping feed&utm_content=free google shopping clicks&gclid=Cj0KCQjw8_qRBhCXARIsAE2AtRZ1BdZ0PU475ejRidwvuq_GJ7AKbxl75M-Blf3VCXjIfUbkhXqlLRoaAsaPEALw_wcB 1 Quote Link to comment Share on other sites More sharing options...
midnightman Posted March 26 Share Posted March 26 I’ve also used Energy Suspension’s polyurethane bushings for a few of those applications. If you look up their online catalog they have a universal section with all kinds of stuff. Have also used Faucher to order mounts(Kinda like our own Canadian version of McMaster-Carr) 1 Quote Link to comment Share on other sites More sharing options...
Sparky Posted March 26 Author Share Posted March 26 18 hours ago, ksfarmdude said: Have any pics of them you can show ? It's funny...as many of these tractors that I've torn apart, I've never really looked that close at these. The tractor these are needing replaced on are just too far gone, and someone has tried to finaggle something out of heater hose and washers it looks like. It's quite the mess, and on top of that, whoever filled it with fuel was pretty messy, too as everything under the tank is "moist", lol. I may have to remove a good one out of another tractor to see what I can come up with. I use McMaster Carr for a lot of stuff, but have never ran across the bushings that Andrew posted, so maybe we hit on something there. Thanks for all the help, guys. Travis Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted March 26 Share Posted March 26 2 hours ago, Sparky said: It's funny...as many of these tractors that I've torn apart, I've never really looked that close at these. The tractor these are needing replaced on are just too far gone, and someone has tried to finaggle something out of heater hose and washers it looks like. It's quite the mess, and on top of that, whoever filled it with fuel was pretty messy, too as everything under the tank is "moist", lol. I may have to remove a good one out of another tractor to see what I can come up with. I use McMaster Carr for a lot of stuff, but have never ran across the bushings that Andrew posted, so maybe we hit on something there. Thanks for all the help, guys. Travis Well A pic of yours would help , But yes I have extras in the parts bin still in the original packaging I think Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted March 26 Share Posted March 26 Doubt these are what your looking for but these are what I was referring too they are "1 in diameter with a 3/8 hole size steel bushing molded into them Quote Link to comment Share on other sites More sharing options...
Dan Robinson Posted March 27 Share Posted March 27 15 hours ago, ksfarmdude said: Doubt these are what your looking for but these are what I was referring too they are "1 in diameter with a 3/8 hole size steel bushing molded into them Those are it. 1 Quote Link to comment Share on other sites More sharing options...
Maynard Posted March 28 Share Posted March 28 On 3/26/2022 at 6:02 PM, ksfarmdude said: Doubt these are what your looking for but these are what I was referring too they are "1 in diameter with a 3/8 hole size steel bushing molded into them Is the small OD about 3/4" Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted March 28 Share Posted March 28 The rubber mount bushings in the pics I posted are Part # is 196504C1 I used them on 1400 series combines under the electro hydraulic valve block 1 Quote Link to comment Share on other sites More sharing options...
