735 plow question
pt756
So we still moldboard plow, have milk cows so there is always old sod to plow up every few years, i was able to get a 735 plow on auction time today, 6 bottom went for 1800 dollars, it has spring reset and came with 6 extra plow shares, came from a local smaller farm, was a one owner, question is our other plows are 720.s with the toggle trips, we dont have a big rock problem to start with,  the one thing i noticed about the 6 bottom 735 plows that a lot are welded where the pivot point is, must be all the same parts as the 720 has? and can you change the width setting while you are plowing?
Some of parts are the same. Yes you can change width on the go if you have a hyd ram on the width settings adjustment. Most 735 i seen required 3 remotes and I seen guys install a turnbuckle in place of the width ram if they were running two remote tractors.
