Sresites Posted March 23, 2022 Share Posted March 23, 2022 I don’t have an answer to this. An iPhone pic will most generally rotate itself to 90 degrees posting on a forum such as this one. Screen shoot that pic and all is fine. Need an answer please. It was mentioned to go to edit and rotate the pic. Edit it where? First pic, of course, a lens shot - the other a screen shot - the third a lens shot pre-rotated 90 degrees before posting. Quote Link to comment Share on other sites More sharing options...
MTB98 Posted March 23, 2022 Share Posted March 23, 2022 Open your photo and tap “Edit” Then tap the rotation box at the bottom and rotate your picture around then DONE 1 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted March 23, 2022 Share Posted March 23, 2022 I will try that, next time one of my pictures goes wrong way. I feel like 90% of the time though, my pictures are fine. Older iPhone here Quote Link to comment Share on other sites More sharing options...
stronger800 Posted March 23, 2022 Share Posted March 23, 2022 oh this is a mess 1 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted March 23, 2022 Share Posted March 23, 2022 I rotated at 90, it posted 180. Or perhaps 540 Quote Link to comment Share on other sites More sharing options...
MTB98 Posted March 23, 2022 Share Posted March 23, 2022 I’ve made it work by turning it all the way around even if it’s right to start with. Sometimes I’ve had to rotate it around and then slightly crop one side and save it then it will post correctly. Different forums use different software that needs special techniques I guess 😂 Quote Link to comment Share on other sites More sharing options...
Sresites Posted March 23, 2022 Author Share Posted March 23, 2022 MTB98 That’s exactly what I did with the original snap shot. What you’re showing is my screen shot. Quote Link to comment Share on other sites More sharing options...
Ian Beale Posted March 23, 2022 Share Posted March 23, 2022 Youmean you can't just rotate the phone and let the plumb bob turn the picture? Quote Link to comment Share on other sites More sharing options...
rrr4quality Posted March 23, 2022 Share Posted March 23, 2022 6 hours ago, MTB98 said: I’ve made it work by turning it all the way around even if it’s right to start with. Sometimes I’ve had to rotate it around and then slightly crop one side and save it then it will post correctly. Different forums use different software that needs special techniques I guess 😂 This is what I have to do for some pictures. If your picture is sideways before you insert it that’s how it will post. Quote Link to comment Share on other sites More sharing options...
MTB98 Posted March 23, 2022 Share Posted March 23, 2022 8 hours ago, Sresites said: MTB98 That’s exactly what I did with the original snap shot. What you’re showing is my screen shot. I saved your photo then took screenshots of the edit process. After you rotate it around and get it into the orientation you want (with iPhone in normal position, home button on the bottom) then crop one edge of the picture slightly then tap DONE. It should post correctly with the photo saved like that. Quote Link to comment Share on other sites More sharing options...
Long Farms Posted March 23, 2022 Share Posted March 23, 2022 This website itself needs a photo rotate edit option when you upload a photo. 2 Quote Link to comment Share on other sites More sharing options...
FarmallFan Posted March 23, 2022 Share Posted March 23, 2022 If the photo is taken in landscape rotation, the iPhone's volume buttons need to point down. Otherwise the image will improperly rotated when viewed anywhere but on the iPhone. 1 Quote Link to comment Share on other sites More sharing options...
Sresites Posted March 23, 2022 Author Share Posted March 23, 2022 My original pic was taken in portrait position, volume buttons to the left. I have the iPhone X. The following pic was taken in landscape position of encroaching development in the background. Quote Link to comment Share on other sites More sharing options...
Gearclash Posted March 23, 2022 Share Posted March 23, 2022 Always take pictures with the phone horizontal and the camera button to the right, i.e. the bottom of the phone to the right. This has pretty much put an end to my picture orientation problems. Quote Link to comment Share on other sites More sharing options...
460 Posted March 23, 2022 Share Posted March 23, 2022 You guys and your fruity phones...I have no issues with a Samsung. 1 Quote Link to comment Share on other sites More sharing options...
mikem Posted March 24, 2022 Share Posted March 24, 2022 9 hours ago, 460 said: You guys and your fruity phones...I have no issues with a Samsung. I do with an S-7... (Might be the operator tho---) Mike Quote Link to comment Share on other sites More sharing options...
