TA Housing question
Hello, guys.
I recently bought a project 706D and discovered somewhat after the fact that it has a cracked Torque/Bell housing.
My guess is that someone let their loader mounts get loose and, well... You know the rest.
I have some parts machines here but nothing in a 7xx size. I do have some 856 parts tractors and was wondering if the TA housings were the same size. If so, would the entire unit be potentially usable or would there be anything that would need to be changed?
TIA
FT
2 hours ago, Dan Robinson said:
Yes they are the same. But the real early ones had a few external casting differences if you want to get real technical.
Yes, and one big difference between the castings is really the reason I had to ask the question.
On the 706, the PN is cast right on the left side, where there is no PN on the ‘56 casting. (at least inthat location)
FT
FT
To 99.99% of people they wouldn't even know if it was changed out.
