5088 Rear Cab Flashers
On my 5088 the front two cab hazard flashers both work and both work with their respective turn signal direction. Neither of the two rear ones work. I have taken both of the bulbs out and both appear to be fine. I have even switched one of the front working bulbs to the back with no change. Last fall when I was testing everything, I could get my test light to light up on the rear wires but it was constant and not flashing.
What I have done so far is changed out the flasher unit under the dash with a new one from Mike at Triple R. Was really hoping this was going to fix it but it didn't make a difference.
I still need to check the rear outlet plug to see if I plugged an implement into if the flasher has power back to it.
Any ideas where to check next? From previous post it sounds like their is a connector under the upper fuel tank that goes to the top of the cab. I'm still a little confused how I was getting power to my test light but it was constant and not flashing.
I second the ground issue. Last summer we bought a our 7230 Magnum. Same issue fronts worked no rears. Ended up being the ground. Cleaned it up and all was good
The dome light on my 5288 stopped working with the door switch. Took cab roof panel off and mice had chewed off the wire to the light. Little $%&holes get up the roll bar and have at it. Plugged the tube and no more problems. Might want to check that out.
Just a quick update. I had time to look around today. Used a jumper wire to the cab and the flashers started working. Weird thing was once I did it to the right one it stay working even after I removed the little jumper wire. I had moved a bunch of wires around under fender but still can’t figure that one out. Regardless i ran a new ground wire to both of the rear flashers and ground it to the cab shell and all is fine.
I appreciate everyone’s help.
