F12 F14 Rear rims centers
Talked to a customer.   Has split rims on the rear of an F12 or F14 ( he has some demensia).  Wants to do away with the split rear rims and go to standard rims.  Not sure if they are 36 or 38 (again, some demensia).  Will a drop center H or M rim fit on the F12 or F14 centers?  Or would cast centers from an H fit on the F12 or F14 axles?  I appreciate your insights.  Thanks!
I think all of them with cast centers had 40" tires so H&M rims will not fit and the axles on them were 2 5/8" so 2 1/2" H wheels will not fit. If you were really motivated, you might get 2 3/4" M wheels to fit with some bushings.
Agree with Torque on this one. The split rims were 40's. I think round spokes were 36 or 38. Cut down steel with the flat spokes welded to a rim is another option. A machinist can possibly bore out an H center.
