AKwelder Posted February 25, 2022 Share Posted February 25, 2022 if I go to replace the clutch, well actually the throw out bearing, on my Farmall 460 what other things should I be looking at while I haver her split? Was planning on a pressure plate, clutch, throw out bearing, and piolet bearing for parts, and if needed I will have the flywheel resurfaced. Any other items to keep in mind? Quote Link to comment Share on other sites More sharing options...
oleman Posted February 25, 2022 Share Posted February 25, 2022 I would replace the rear main seal while you are in there. Others would say, if it doesn't excessively leak leave it alone. I assume you are accumulating parts because it's a little nippy way up north! Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted February 25, 2022 Share Posted February 25, 2022 You'll seen a lot of black gunck inside after you split it Depending on what type of work your doing with it I'd go with a solid clutch disc surface the flywheel too and use good Quality parts , I wouldn't worry about the engine rear main seal unless its obviously leaking inspect the pto spines for wear and any transmission leaks there also Quote Link to comment Share on other sites More sharing options...
VacDaddyt Posted February 25, 2022 Share Posted February 25, 2022 Look at the splines that go into the clutch pressure plate on the pto side to see how bad they are worn. That also run the hydraulics. Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted February 25, 2022 Share Posted February 25, 2022 5 minutes ago, VacDaddyt said: Look at the splines that go into the clutch pressure plate on the pto side to see how bad they are worn. That also run the hydraulics. No need when he's replacing the pressure plate it will already have new splines Quote Link to comment Share on other sites More sharing options...
hippy5488 Posted February 25, 2022 Share Posted February 25, 2022 30 minutes ago, ksfarmdude said: No need when he's replacing the pressure plate it will already have new splines vac daddy is saying the pto input shaft Quote Link to comment Share on other sites More sharing options...
hippy5488 Posted February 25, 2022 Share Posted February 25, 2022 no need to put a new clutch in if flywheel isnt turned to specs. and check min. thickness Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted February 25, 2022 Share Posted February 25, 2022 4 minutes ago, hippy5488 said: vac daddy is saying the pto input shaft So did I in my first post Quote Link to comment Share on other sites More sharing options...
VacDaddyt Posted February 26, 2022 Share Posted February 26, 2022 (edited) yep I got ahead of myself with reading. Edited February 26, 2022 by VacDaddyt clarification Quote Link to comment Share on other sites More sharing options...
AKwelder Posted February 26, 2022 Author Share Posted February 26, 2022 6 hours ago, VacDaddyt said: Look at the splines that go into the clutch pressure plate on the pto side to see how bad they are worn. That also run the hydraulics. Guess I need to look at how that works. Never been in one Quote Link to comment Share on other sites More sharing options...
AKwelder Posted February 26, 2022 Author Share Posted February 26, 2022 Found this thread fair enough. Thanks for the pointers. regarding quality of parts. Any suggestions for buying or avoiding? I am not farming with this tractor, but I would like to keep it in good enough condition to farm. And I sure don’t want to do it again. now I get to build some splitting stands Quote Link to comment Share on other sites More sharing options...
bitty Posted February 26, 2022 Share Posted February 26, 2022 5 hours ago, AKwelder said: Found this thread fair enough. Thanks for the pointers. regarding quality of parts. Any suggestions for buying or avoiding? I am not farming with this tractor, but I would like to keep it in good enough condition to farm. And I sure don’t want to do it again. now I get to build some splitting stands Don't know what shipping would be but Lehman tractor should be able to get what you need Quote Link to comment Share on other sites More sharing options...
AKwelder Posted February 26, 2022 Author Share Posted February 26, 2022 5 hours ago, bitty said: Don't know what shipping would be but Lehman tractor should be able to get what you need Shipping is going to be what it is. I use the tractor for snow removal, it pays its way Quote Link to comment Share on other sites More sharing options...
