Brockpend Posted February 23, 2022 Share Posted February 23, 2022 Need a battery for a 460, what size battery does that engine need? I imagine it needs to be relatively big. Quote Link to comment Share on other sites More sharing options...
TomH Posted February 23, 2022 Share Posted February 23, 2022 Group 65 850 CCA should do it. Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted February 23, 2022 Share Posted February 23, 2022 I like to get as close to 1000 CCA as I can for bigger motors but I imagine 850 would work. 1 Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted February 23, 2022 Share Posted February 23, 2022 Deep cycle to allow for extended cranking........... Always get the biggest that will fit and you can afford 2 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted February 23, 2022 Share Posted February 23, 2022 You know, a lot of stuff around here gets group 24 batteries, I have a lot of 3 year old take outs every year, one of them whipped a gas 460 over just fine. I have one on my M as well. I am a fan of big batteries, preferably duals but i am always amazed. 2 Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted February 23, 2022 Share Posted February 23, 2022 1 hour ago, vtfireman85 said: You know, a lot of stuff around here gets group 24 batteries, I have a lot of 3 year old take outs every year, one of them whipped a gas 460 over just fine. I have one on my M as well. I am a fan of big batteries, preferably duals but i am always amazed. I always used group 24 in most of my machines that use that style. Then I discovered that group 34 batteries fit and have more CCA. Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted February 23, 2022 Share Posted February 23, 2022 13 minutes ago, nepoweshiekfarmalls said: I always used group 24 in most of my machines that use that style. Then I discovered that group 34 batteries fit and have more CCA. I have a nearly endless supply of free group 24-R, we pull them at 3 years from generators and they usually go another year or 2 1 Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted February 23, 2022 Share Posted February 23, 2022 always use free batteries before buying any 2 1 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted February 23, 2022 Share Posted February 23, 2022 17 minutes ago, nomorejohndeere said: always use free batteries before buying any Why would I buy a new one when i have one sitting there? Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted February 23, 2022 Share Posted February 23, 2022 Are 560 12 volt? Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted February 23, 2022 Share Posted February 23, 2022 1 hour ago, nomorejohndeere said: Are 560 12 volt? Yes. Quote Link to comment Share on other sites More sharing options...
oleman Posted February 23, 2022 Share Posted February 23, 2022 Group 31 is the battery, if the box is large enough. Actually cheaper than many smaller batteries because they are so common in commercial equipment. Quote Link to comment Share on other sites More sharing options...
Brockpend Posted February 24, 2022 Author Share Posted February 24, 2022 3 hours ago, oleman said: Group 31 is the battery, if the box is large enough. Actually cheaper than many smaller batteries because they are so common in commercial equipment. Would this work with my 460? Don’t see any reason why it shouldn’t. It’s 1000 cca Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted February 24, 2022 Share Posted February 24, 2022 8 minutes ago, Brockpend said: Would this work with my 460? Don’t see any reason why it shouldn’t. It’s 950 cca Long as it will fit in the tray and the cables will reach the correct terminals. Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted February 24, 2022 Share Posted February 24, 2022 That looks like a deep cycle tho with the threaded terminals? Quote Link to comment Share on other sites More sharing options...
Brockpend Posted February 24, 2022 Author Share Posted February 24, 2022 4 minutes ago, iowaboy1965 said: That looks like a deep cycle tho with the threaded terminals? Cables will reach. I’m pretty sure they make adapters that screw onto those. If not I’ll change the ends out on the cables. What does deep cycle mean though? I do not know? Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted February 24, 2022 Share Posted February 24, 2022 Deep cycle=Camper or boat battery made to be used longer without being charged. More reserve capacity. Not a bad thing but not really needed in an automotive application either. I assume a bit more expensive.... Quote Link to comment Share on other sites More sharing options...
jass1660 Posted February 24, 2022 Share Posted February 24, 2022 Changing cable ends leads to another spot for corrosion 1 Quote Link to comment Share on other sites More sharing options...
midnightman Posted February 24, 2022 Share Posted February 24, 2022 Around here the parts stores have those batteries with either threaded or post terminals depending on your application 1 Quote Link to comment Share on other sites More sharing options...
Brockpend Posted February 24, 2022 Author Share Posted February 24, 2022 6 minutes ago, iowaboy1965 said: Deep cycle=Camper or boat battery made to be used longer without being charged. More reserve capacity. Not a bad thing but not really needed in an automotive application either. I assume a bit more expensive.... Well I’d like to go with this if it’s not a bad thing. I imagine a 460 from the 70s will definitely need to be turned over a little more to get it to start lol Quote Link to comment Share on other sites More sharing options...
1480x3 Posted February 24, 2022 Share Posted February 24, 2022 I got duals on my 2021 7.3, a single is standard. Don't know the CCA of them, think the 7.3 is around 440 ci. Never did the math. Quote Link to comment Share on other sites More sharing options...
int 504 Posted February 24, 2022 Share Posted February 24, 2022 They make regular batteries with threaded posts. Commonly used in boats. Some have center position posts or studs. Quote Link to comment Share on other sites More sharing options...
Brockpend Posted February 24, 2022 Author Share Posted February 24, 2022 33 minutes ago, iowaboy1965 said: That looks like a deep cycle tho with the threaded terminals? After researching this. It is not a deep cycle 1 Quote Link to comment Share on other sites More sharing options...
Craig61019 Posted February 24, 2022 Share Posted February 24, 2022 I have a 1000 CCA in my 1977 F-250 that doesn’t get driven much in the winter months, started it today for the first in 2022, plugged in the block heater ,waited a while and it took right off😎 Quote Link to comment Share on other sites More sharing options...
Brockpend Posted February 24, 2022 Author Share Posted February 24, 2022 58 minutes ago, Craig61019 said: I have a 1000 CCA in my 1977 F-250 that doesn’t get driven much in the winter months, started it today for the first in 2022, plugged in the block heater ,waited a while and it took right off😎 460? Quote Link to comment Share on other sites More sharing options...
