nate Posted March 3, 2022 Author Share Posted March 3, 2022 7 hours ago, iowaboy1965 said: One thing about it, you will know what you got when your done. And hopefully will get many more years of service from it. That is the end goal…. Fix it and hopefully get another 7000 plus hours out of it. 3 Quote Link to comment Share on other sites More sharing options...
89vmax Posted March 4, 2022 Share Posted March 4, 2022 I've considered getting synchro discs just because of I'm concerned about NLA Quote Link to comment Share on other sites More sharing options...
acem Posted March 4, 2022 Share Posted March 4, 2022 What 88 series service tools did you buy? Quote Link to comment Share on other sites More sharing options...
nate Posted March 4, 2022 Author Share Posted March 4, 2022 3 hours ago, acem said: What 88 series service tools did you buy? They are the OTC tools for the 88 series tractors. I’ll take a pic of them when I get back down to the farm. 1 Quote Link to comment Share on other sites More sharing options...
midnightman Posted March 5, 2022 Share Posted March 5, 2022 6 hours ago, nate said: They are the OTC tools for the 88 series tractors. I’ll take a pic of them when I get back down to the farm. I’d like to see a picture of what you got. Bought a bunch at dealer close out auction a few years ago. Haven’t had to use them yet so don’t really know if everything is there Quote Link to comment Share on other sites More sharing options...
88seriesrestorer Posted March 5, 2022 Share Posted March 5, 2022 On 3/2/2022 at 8:32 PM, nate said: @88seriesrestorer Hey Mike. My brother got parts from you today. Quick question. The synchro retainers, how important are they? Once together are they needed?? Thanks. Talked to him on the phone. You need anything let me know Quote Link to comment Share on other sites More sharing options...
nate Posted March 7, 2022 Author Share Posted March 7, 2022 Made some progress, It is going back together. Cleaning parts and started assembling range today. Pic of master clutch just about ready, just needs Teflon’s put on.. 3 Quote Link to comment Share on other sites More sharing options...
nate Posted March 7, 2022 Author Share Posted March 7, 2022 On 3/4/2022 at 9:30 AM, acem said: What 88 series service tools did you buy? Pic of the tools Acem 4 Quote Link to comment Share on other sites More sharing options...
nate Posted March 9, 2022 Author Share Posted March 9, 2022 Worked on it some last night. Assembled shafts in the speed trans. 3 Quote Link to comment Share on other sites More sharing options...
Delta88 Posted March 9, 2022 Share Posted March 9, 2022 Wow That really shows us novices how it all goes back together. Quote Link to comment Share on other sites More sharing options...
nate Posted March 10, 2022 Author Share Posted March 10, 2022 10 hours ago, Delta88 said: Wow That really shows us novices how it all goes back together. We are new to this as well. First 88 series we’ve been into. Quote Link to comment Share on other sites More sharing options...
nate Posted March 10, 2022 Author Share Posted March 10, 2022 Anyone have any issues with the neutral switches? This one was folded over, got it straightened out and back adjusted but it wants to catch and fold over when it’s adjusted to where the switch works. Quote Link to comment Share on other sites More sharing options...
Joninva Posted March 10, 2022 Share Posted March 10, 2022 My 54 did the same thing. Got a new switch from mike but haven't put it on yet. Quote Link to comment Share on other sites More sharing options...
pirlbeck Posted March 10, 2022 Share Posted March 10, 2022 Kind of hard to tell from the pictures, but be sure to lube the shaft and gears when assembling, or they may seize to the shaft on start up, before the pressurized lube oil gets to them. The thrust surfaces of the gears and thrust washers need lubrication also. Quote Link to comment Share on other sites More sharing options...
ihrondiesel Posted March 10, 2022 Share Posted March 10, 2022 14 hours ago, nate said: Anyone have any issues with the neutral switches? This one was folded over, got it straightened out and back adjusted but it wants to catch and fold over when it’s adjusted to where the switch works. That’s the neutral start switch, right? I relocated mine so it is now a “parking brake on start switch”. Quote Link to comment Share on other sites More sharing options...
nate Posted March 11, 2022 Author Share Posted March 11, 2022 15 hours ago, pirlbeck said: Kind of hard to tell from the pictures, but be sure to lube the shaft and gears when assembling, or they may seize to the shaft on start up, before the pressurized lube oil gets to them. The thrust surfaces of the gears and thrust washers need lubrication also. We oiled the shaft when going together and are going to pour oil over gears and bearings before range and speed get mated. Also are going to force some oil thru the shafts. Or is there a better way?? Thanks. 1 Quote Link to comment Share on other sites More sharing options...
pirlbeck Posted March 11, 2022 Share Posted March 11, 2022 5 minutes ago, nate said: We oiled the shaft when going together and are going to pour oil over gears and bearings before range and speed get mated. Also are going to force some oil thru the shafts. Or is there a better way?? Thanks. So long as you lubed the shaft before sliding the gears on you should be fine. I just though that looking at the pictures things looked a little "dry". Forcing some oil into the shaft sure would not hurt anything either. Quote Link to comment Share on other sites More sharing options...
nate Posted March 11, 2022 Author Share Posted March 11, 2022 9 hours ago, ihrondiesel said: That’s the neutral start switch, right? I relocated mine so it is now a “parking brake on start switch”. Yes it is, Here is my scrap metal engineered update. Time will tell if it hold up, but seems to work smoothly and doesn’t want to catch and bend anymore. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted March 12, 2022 Share Posted March 12, 2022 The inside of your transmission housings are Grey. Mine are primer red. Thx-Ace. Quote Link to comment Share on other sites More sharing options...
nate Posted March 12, 2022 Author Share Posted March 12, 2022 19 minutes ago, acem said: The inside of your transmission housings are Grey. Mine are primer red. Thx-Ace. They are closer to black in person, lighting makes them look grey. Yours must be an early model Ace? Quote Link to comment Share on other sites More sharing options...
acem Posted March 12, 2022 Share Posted March 12, 2022 I think it's an 83 but I'd have to check to be sure. It has the ab100 pump and the newer hydraulic handles. Thx-Ace Quote Link to comment Share on other sites More sharing options...
nate Posted March 14, 2022 Author Share Posted March 14, 2022 The motor came apart this weekend to see what parts we need. Pressure tested cooling system before it was tore down to see where coolant was leaking in pan #2 was culprit. Also found where excessive blow by came from. #6 had a broken ring. There was scoring on piston near piston pin ends on a few. Now the question of what kit to get??? Quote Link to comment Share on other sites More sharing options...
acem Posted March 14, 2022 Share Posted March 14, 2022 Does Navistar still have good parts available? Surely someone makes parts for a dt466 here in the states... Thx-Ace Quote Link to comment Share on other sites More sharing options...
Only RED in the shed Posted March 15, 2022 Share Posted March 15, 2022 I work at a Navistar dealer and you can get dt kits but not sure where they come from. Haven't had any issues with them yet but who knows when Volkswagen starts messing with things Quote Link to comment Share on other sites More sharing options...
hippy5488 Posted March 15, 2022 Share Posted March 15, 2022 On 3/10/2022 at 2:08 PM, ihrondiesel said: That’s the neutral start switch, right? I relocated mine so it is now a “parking brake on start switch”. there is plastic bushings in the cross tubes for shifter and park. they wear out and let it drop down causing this problem Quote Link to comment Share on other sites More sharing options...
