acem Posted February 20 Share Posted February 20 Be sure to drain the coolant before pulling the injectiors. Sometimes the cup will pull out with the injector, filling the cylinder with coolant!Thx-Ace Quote Link to comment Share on other sites More sharing options...
td9inidaho Posted February 20 Share Posted February 20 48 minutes ago, acem said: Be sure to drain the coolant before pulling the injectiors. Sometimes the cup will pull out with the injector, filling the cylinder with coolant!Thx-Ace It's funny how when we want to get those cups out we can't, last time I had to pull the head and use a Dremel to cut the cup into pieces to get it out. Then again, someone wanting to just take an injector out, they come right out 😂😂 Good luck, good save. Sad to see stuff like this go to scrap. Mark 1 Quote Link to comment Share on other sites More sharing options...
Dax DeCelle Posted February 21 Author Share Posted February 21 8 hours ago, acem said: Be sure to drain the coolant before pulling the injectiors. Sometimes the cup will pull out with the injector, filling the cylinder with coolant!Thx-Ace Thank you for telling me that. I didn’t think about it. I drained 3 gallons of good, clean coolant out of it. That got it out of the head. Quote Link to comment Share on other sites More sharing options...
bitty Posted February 21 Share Posted February 21 8 hours ago, td9inidaho said: It's funny how when we want to get those cups out we can't, last time I had to pull the head and use a Dremel to cut the cup into pieces to get it out. Then again, someone wanting to just take an injector out, they come right out 😂😂 Good luck, good save. Sad to see stuff like this go to scrap. Mark Take a 5/8"? tap , cover it with grease and tap down into the cup. Sometimes it will spin just from that . Otherwise install a bolt on a slide hammer or even a bolt and washer and pry bar it out Quote Link to comment Share on other sites More sharing options...
snoshoe Posted February 21 Share Posted February 21 59 minutes ago, bitty said: Take a 5/8"? tap , cover it with grease and tap down into the cup. Sometimes it will spin just from that . Otherwise install a bolt on a slide hammer or even a bolt and washer and pry bar it out Original was a plastic cap shoved down in the sleeve. A wad of paper in the bottom is safer than the grease. 1 Quote Link to comment Share on other sites More sharing options...
Dax DeCelle Posted March 22 Author Share Posted March 22 Thought someone might like to see what developed with this one. After a heck of a fight getting the injectors out, and sucking lots of water out, I filled the cylinders with Marvel Mystery Oil and let it soak for 3 weeks. After trying the biggest cheater I’ve ever tried, I pulled the head to find a seriously rusted situation. Won’t be firing this one up without some new liners and rings at minimum. It’ll go in a shed for now. 2 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted March 23 Share Posted March 23 Awww. Good try. At least the price was still right. Quote Link to comment Share on other sites More sharing options...
