IHFarmer07 Posted February 12, 2022 Share Posted February 12, 2022 Evening all, I’ve got a 756 with a 310 German that has a antifreeze/coolant leak that is coming from around the number 1 injector area(will confirm exactly where tomorrow). Was curious if anyone here has ran into this issue? Has anyone changed injector sleeve/cups on a German? What tools are needed to take out and reinstall the sleeve/cup? Can the injector sleeve/cup be installed with the head in place? Quote Link to comment Share on other sites More sharing options...
frank.nl Posted February 12, 2022 Share Posted February 12, 2022 Quote Link to comment Share on other sites More sharing options...
td9inidaho Posted February 12, 2022 Share Posted February 12, 2022 It seems we need a translator to read that manual to know what it's saying 😂😂 Mark Quote Link to comment Share on other sites More sharing options...
IHFarmer07 Posted February 12, 2022 Author Share Posted February 12, 2022 19 minutes ago, td9inidaho said: It seems we need a translator to read that manual to know what it's saying 😂😂 Mark Yeah🙄🤦🏻🤦🏻 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted February 12, 2022 Share Posted February 12, 2022 I can't translate but this is what we did. Plug bottom of sleeve. Run tap into body of sleeve. A threaded adapter threaded into sleeve and onto bottom of 5 lb. slide hammer. That removed sleeve. Installing tool was basically shaped like a nozzle body. With pilot that aligned bottom of sleeve with hole in head. Best I can remember a shoulder drove from top edge of sleeve. I need verification on that. Sealed with green loctite. Quote Link to comment Share on other sites More sharing options...
frank.nl Posted February 12, 2022 Share Posted February 12, 2022 German engine---- German manual Quote Link to comment Share on other sites More sharing options...
IHFarmer07 Posted February 13, 2022 Author Share Posted February 13, 2022 8 hours ago, snoshoe said: I can't translate but this is what we did. Plug bottom of sleeve. Run tap into body of sleeve. A threaded adapter threaded into sleeve and onto bottom of 5 lb. slide hammer. That removed sleeve. Installing tool was basically shaped like a nozzle body. With pilot that aligned bottom of sleeve with hole in head. Best I can remember a shoulder drove from top edge of sleeve. I need verification on that. Sealed with green loctite. Thank you! I’ve got a jensales German engine manual but I haven’t combed through it just yet. I wanted to confirm what we thought was the issue. We were correct, the bottom of the sleeve is cracked and it’s leaking pretty good. Quote Link to comment Share on other sites More sharing options...
IHFarmer07 Posted February 13, 2022 Author Share Posted February 13, 2022 8 hours ago, frank.nl said: German engine---- German manual Lol yeah your not wrong there! I sure do appreciate the time it took for you to post! I’m of German decent but I don’t know any German. Thank you! Quote Link to comment Share on other sites More sharing options...
