How many 766 gas tractors built?
Pete1468
My suggestion is to buy a John Deere gas tractor. They have to be the most evilest tractor out there to get started. Not the engines fault the hydraulic pump took more hp to turn than the starters could supply.  A 766 gas would be a unique tractor to have . One day I would like to have the 06 through 86 series lineup always a dream to try to fulfill.
2640 Diesel, messed with it forever.
Finally scraped the starter, high torque aluminum, heavy cables to the block and starter, problem solved.
Deere dealer wanted me to put their fancy crank HYD delete valve in.
That little starter, heavy cables and new pair of batteries..
Very doable on the coldest days.
Ashamed to talk up green like this!
Maybe unwelcome here but those older Oliver gas engines are about as un cold blooded as they come. Don't know what is so special about them but they are nice in the winter. 1600 -  1655 or 1700 -  1755.  And no I don't have one, but worked on several.
Lots of those running loaders up here and they were reliable.
Was at an auction a month ago, Bitterly cold out.   They had a Oliver Super 77 gas that was started and PURRING.  Smoothest running old gasser I've ever heard.   The M right beside it they could not get started.   Lot of us were warming up our hands on the Oliver manifold....it was so cold you could put your hands right on the manifold and not get burned!
My distant cousin ,buddy has a 1650 Oliver that the uncle  bought new with a f25 farmhand loader. They had a 1550 with f10 they sold when uncle sold this one. They fed between 500 and 1200 calves every year with it. He was telling me that flat hood was great. Really cold weather walk out on hood kneel down and grab onto muffler with gloves. They ran those Oliver’s a lot other than clutches they were good.
I have a don't know how old 77 that was sold new and lived it's life down here on the river. I am the third owner. It has always started easy and motor impressed me as running quiet and smooth as a sewing machine.
With a pto pump it just may find new life powering the hyd chute.
Sandhiller, 1953 by serial number.
https://www.tractordata.com/farm-tractors/000/6/7/671-oliver-77.html
77 Serial Numbers
Location: early: rear main frame and transmission, front-right side
  later: below instrument panel
1948: 320001
1949: 320241
1950: 327901
1951: 337243
1952: 347904
1953: 3500001
1954: 4501667
Final: 4504470
@sandhiller meaning yours is the 5th build in 1953. Since the first was 3500001 and yours is 3500006
77 Serial Numbers
1948: 320001
1949: 320241
1950: 327901
1951: 337243
1952: 347904
1953: 3500001
1954: 4501667
Final: 4504470
I was real close to buying a Allis wd about a month ago, biggest drawback for me is it has to have a fast hitch for a yard tractor.  It's way too handy to not use a jack to hook things up.
After using a fast hitch for that type of work I agree. Brother has a 656 NF 263 gas FH , we also have a 706 gas
I did find a 686 German diesel, dad bought one new and that would be my weakness, that was the gutsyist 65 HP tractor I was ever around.
Well, a WD has the lift arms. I have a hold my beer idea.   Make a fasthitch wishbone work under a Wd or wd45.  I think the wishbone needs to sit in front of the allis mounting point for the prong points to be in the right place relative to the pto shaft. I had a few adult beverages a few years ago and took a tape measure between the 400 and the wd.  Didn't write down anything....
Karl
Karl
Interesting thought. I may look into this when it warms up. I have a couple of snap-coupler three point adapters, maybe a guy could 'install' the lift-arm pockets on from a fast hitch. Geometry could be an issue though.
The IH 263 gas has always been a reliable starting engine in cold weather.   All the ones we have owned: throttle at 1/4, pull choke out, crank until it fires, ease choke off slowly as engine warms up. ( Usually in 2 to 3 increments: they will let you know!) A strong battery, good cables and connections and good contacts on the points.... they will start and run.
Yep.  Take their time warming up, but they DO start.  I usually let my 706 gas idle to warm up about half choke for 10 minutes.
