SouthernClassic Posted February 1 Share Posted February 1 So it is pretty easy to find a 544 row crop with gas engines. I got to think could you repower one with a diesel engine from the utility version without much hassle or would it not match up? Quote Link to comment Share on other sites More sharing options...
Eason Posted February 2 Share Posted February 2 It should be a direct bolt in. Quote Link to comment Share on other sites More sharing options...
Michigan No Till Posted February 2 Share Posted February 2 Would that be a Nuess, German engine? Quote Link to comment Share on other sites More sharing options...
606 diesel Posted February 2 Share Posted February 2 19 minutes ago, Michigan No Till said: Would that be a Nuess, German engine? Yes, a d239 german to be precise. Quote Link to comment Share on other sites More sharing options...
brewcrew Posted February 2 Share Posted February 2 You need more than just the basic engine. The fuel tank, throttle linkage, radiator, probably air cleaner. And if you’re thinking about getting the engine from an 84 series utility, you might need more yet. 1 Quote Link to comment Share on other sites More sharing options...
Super A_sepa Posted February 2 Share Posted February 2 Probably need the starter too and would be easiest to get an engine from a tractor with the same trans because you'll need the right flywheel as well. Quote Link to comment Share on other sites More sharing options...
Michigan No Till Posted February 2 Share Posted February 2 Here ya go, ready to go. Quote Link to comment Share on other sites More sharing options...
Michigan No Till Posted February 2 Share Posted February 2 Lot of cash for a 45hp, tractor! Oh I have no connection to the tractor. Like my 756 Nuess power, with the M&W windmill. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted February 2 Share Posted February 2 1 hour ago, Super A_sepa said: Probably need the starter too and would be easiest to get an engine from a tractor with the same trans because you'll need the right flywheel as well. All hard to find parts, because they didn't make many of them, and most of those are still out in the wild. Quote Link to comment Share on other sites More sharing options...
R190 Posted February 2 Share Posted February 2 its going to take a lot of parts from the radiator to flywheel along with the throttle linkage and wireing harnes to do it correctly. engine mounts starter everthing needs to change. Quote Link to comment Share on other sites More sharing options...
SouthernClassic Posted February 3 Author Share Posted February 3 14 hours ago, Michigan No Till said: Lot of cash for a 45hp, tractor! Oh I have no connection to the tractor. Like my 756 Nuess power, with the M&W windmill. 45hp is a good size for our area. But it was more of a just thinking if it could be done easy. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted February 3 Share Posted February 3 13 hours ago, R190 said: its going to take a lot of parts from the radiator to flywheel along with the throttle linkage and wireing harnes to do it correctly. engine mounts starter everthing needs to change. 544 Utility has frame rails same as the Farmall. Uses the same bell housing, ta housing, differential housing. The difference is in the diameter of the rear tires and the position of the operator's platform. Should be a bolt-in. IF you've got the Utility for parts you can reuse most of those parts, perhaps with a little modification. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted February 5 Share Posted February 5 Strange, I should have come down a couple posts. I asked the same question... Quote Link to comment Share on other sites More sharing options...
