5488 split and rebuild.
Weapon
42 minutes ago, IHC5488 said:
Well on your way....nice shop to work in, plenty of light.....
Clutch looks........ Like toast.....
Did you have any trouble getting the cab mount bolts out of the frame of the cab....that threaded square that sits in between the tranny and cab frame had to be the worst idea ever.
Matt
Ya it took a bit since we weren’t sure which way they threaded thru. But the dewalt impact powered thru no problem. Need to build a stand for the speed trans and separate it. Believe we lost the hi/lo speed clutches.
More to come
John
17 hours ago, Weapon said:
Tore into speed trans. High low showing signs of wear. Anyone know if these are the updated parts. 4A7F2BAD-9708-495E-AA37-739DF082EF3F.thumb.jpeg.49faff21f566f4595c42ddfc23cf515b.jpeg0A22F8AA-F8E6-4C89-8F0D-DC5A161F36D7.thumb.jpeg.a077c589d855435f2f478f1d4c97dc19.jpeg
thx, John
The clutch disks appear to be the updated design. Coarse teeth on them like the Magnums had. Original design had more, smaller teeth on the disks. Was common to round off the teeth on the disks on the original design.
Sorry got sidetracked on other projects. The even gear is 39 teeth. Parts on order waiting for arrival. Whenever I can cross the border again without fear of detention I’ll be ordering chassis parts from triple r.
John
Just an update. My parts are being held hostage by the truck blockade at the Michigan/Ontario border crossing. Hopefully next week sometime.  In meantime I’m tearing into a 510 loader that needs new arm bushings.
John
