IH47 Posted January 19, 2022 Share Posted January 19, 2022 I'm looking at a TD14A with model number BHF-TD14W serial number 4305. It doesn't have the blade set up that I see in the pictures. The blade lift is in between tracks and frame. Quote Link to comment Share on other sites More sharing options...
hardtail Posted January 19, 2022 Share Posted January 19, 2022 That was a style more like a loader setup, don't see many that way but the odd one. The serial numbers were sequential so it should be 1942 Quote Link to comment Share on other sites More sharing options...
ray54 Posted January 20, 2022 Share Posted January 20, 2022 The early TD 14 would of mostly had Bucyrus-Erie blade. Cable or hydraulic, a big chunk iron on the sides of the tractor. They got the dirt moved until engineers figured out better ways. Quote Link to comment Share on other sites More sharing options...
IH47 Posted January 20, 2022 Author Share Posted January 20, 2022 10 hours ago, ray54 said: The early TD 14 would of mostly had Bucyrus-Erie blade. Cable or hydraulic, a big chunk iron on the sides of the tractor. They got the dirt moved until engineers figured out better ways. I’m between tracks and frame, or outside tracks? Quote Link to comment Share on other sites More sharing options...
louie figone Posted January 20, 2022 Share Posted January 20, 2022 IH47, The TD14A was built between 1949 and 1955. Can you post a picture or two of the tractor? There were many different blade manufactures. 1 Quote Link to comment Share on other sites More sharing options...
hardtail Posted January 21, 2022 Share Posted January 21, 2022 Yes there were quite a few different manufacturers and styles a Pic would help us out Quote Link to comment Share on other sites More sharing options...
ray54 Posted January 21, 2022 Share Posted January 21, 2022 B-E used several designs. Outside track I would guess was the most common. But many where on inside and outside the track. Look at the 64 year old TD 14 tread real close to yours here. The first TD 14 is very late model but TD9 farther in the tread has a B-E blade or clone anyway. Quote Link to comment Share on other sites More sharing options...
