When do you need a CDL Heavy (heavy equipment, Tractors ?)
dale560
Just reading through the cdl requirements and this popped in my head. A lot of people up here do snow removal with payloaders. While they operate on private driveways or parking lots they have to travel streets between jobs. The law is any vehicle over 26001 lbs, you need a cdl. Most medium size 544 or 624k jds up here are right above that or heavier. So what do you guys think? I know farm equipment is exempt but that isn’t used for hire on duty streets and if it was it isn’t exempted operations. I will post the statutes and law here what do you guys think. I know years ago a big 988 size loader got a overweight ticket driving on the Street in Minot during weight restrictions they had tires mounted or service work were moving it back to shop and they got nabbed. These are the century codes for North Dakota as I read them then yes you would need one for anything over 26001 lb. they define vehicle as anything self propelled.
  • Replies 54
  • Created
  • Last Reply
I know it's exempt in PA.Thats why so many custom manure haulers, chopping crews went away from trucks to tractors and carts. NO CDLs,no on road fuel usage,no tags, permits. Anyone can be in that tractor cab as long as they can reach the pedal and can push the throttle full bore ahead.And believe me I seen Mennonite kids 10 years old full bore in Fendt tractors pulling 3 axle manure tankers as fast as they will go with zero regard for traffic or what might happen if they can't get it stopped.
As I understand it the loader is not a commercial vehicle because it is designed for off road use.
However it might still be required to comply weight restrictions. You wouldn't want a 15 ton loader on a bridge rated for  2 ton.
Thx-Ace
That's a scary picture
Truck cranes are a good example for your question. If they have a boom dolly, they are considered part of the crane and you still don’t need a class a cdl, but they will most likely have air brakes and then you have to have air brake endorsement.
Wheel loaders are considered off road equipment here, and if being driven on the road, they will need an SMV and flashers. But I would call your state highway patrol to verify your state’s laws.
You need a "hydraulic" license to operate any equipment off your own property here.
Then a loader would need to be registered with a transport plate to be operated on a public road and falls under the CDL weight guidelines.
So basically you need two license here
Just now, jeeper61 said:
Oh and with the transport plate you need to have a safety inspection sticker also
soooo.  while going for inspection.....(no certified inspectors /credentialed )do you swing by the the DVM test track for the license?  would you need to bring a long a full bucket also?
It is actually called a Excavator and Hoisting License there is written and a behind the controls exam.
You can go the the state's site or they can come to your yard or job site
They would make it mandatory to be a union member also if they could get it passed by the legislators
They passed a law now that will require you to go to a truck driving school to get a CDL.
And I believe that is going to be nation wide.
They just want to get their hands in your wallet anytime they can and of course it is all about making you conform.
Put your mask on and study for the test
Material covered in this course:
Proper equipment setup
Jobsite safety
Component recognition
Introduction to Hydraulic Theory
Inspection parameters
Standard hand signals
Safety standards wisdom
Introduction to excavators
Excavator safety
I found the answers to my question just a bit ago. Under the FMSCa site. It explains most of the common questions. These are rules that almost every state follows.
 1 You do need a cdl for a crane if it is transported on roads between jobs.
  2  there is no air brake endorsement just a restriction. You can drive a truck under 26001 lb with air brakes and a class D license.
  3. There is a ag exemption for most of the cdl requirements. There is also a exemption of custom harvesting that is where the kids driving tractors and hauling ag products are exempt.
   4. There are very limited exemptions for firefighters and emergency personnel. And a specific snow removal exemption for municipalities.
  5. One of the questions they answered was mine . Heavy equipment as long as it is being transported to site or driven you are okay. You can’t use it for transportation or engage in commerce with it then you do.
Its area specific! ---around here you have to have CDL for most anything operated for pay.  In this area you have to have to have CDL to drive for the township, county, and state, even if its just their pickup or small skidloader. -- check your LOCAL laws first and see what they recommend  to be safe!
Jobsite safety
Excavator safety
Good lord.  So if I run my loader down the road to pickup bales on a property I own I need a license, a plate, etc?  What is next?  They forgot the license to move in together or pro create.  I would say get married but many just shack up anymore.
There are definitely some kids operating this equipment that shouldn't be, at least out on the road anyway.
There was a fatal accident last year where someone fell asleep in a car and ran into a fendt tanker tractor head on.  The tractor operator reacted appropriately and wasn't at fault.  Im not so sure an inexperienced operator would have had the same outcome.
I believe our laws are al ost the same as yours. There is a set of guidelines the federal government has and only a few exemptions vary state to state. And as I read it we would need a cdl in town or for the county. The point that sets this apart is we are operating on the streets all the time not moving from job to job. Here at the city they will let you take the cdl test while clocked in so I went and got mine and are working on all the endorsements except for bus driving. I figure why not if it is on work time. The other fellows are griping because they had their CDLs before and one guy can’t because of lifetime alcohol suspension. When I started at city they said you don’t need cdl but that is as our supervisors not the mayor or city attorney and as it turns out you definitely do for trucks and I would say the loader , blade and such also. One of our public works committee man is a just retired patrolman / truck inspector from ND hiway patrol. He will know or have access to the right answers.
If you are a registered farm then you can operate on the road with out the license, plate and inspection for agricultural reasons i.e. going between fields, hauling crop etc.....
If you are going down the road to do work for money like loading gravel etc.... you need them all
The other requirement in our state is you need a medical card just like CDL
IMO its just gone to far
As I see it you need the license to mow lawns for money
And some urban cities have made the requirement for all operation so you technically you can't operate on your own property unless you have a farm classification.
Below is the requirement for the need of the license
"An Excavator and Hoisting License is required to operate power construction equipment that uses steam, internal combustion engines, electric or compressed air of five (5) horsepower or more and/or lift more than 500 pounds. Hoisting Engineers also use machinery to move construction materials, excavate earth and other heavy materials and to apply asphalt and concrete to roads and other structures."
Another place people don’t realize you need a cdl. Is pulling trailer behind a pickup. If it is over 10,000 lbs you need a license. That is trailer and load being 10,000 lbs or more. If it is legitimate ag related you can be exempt but hauling your tractor to a show doesn’t fly. That and gooseneck trailer. If pickup , trailer are gvwr combined over 26000 you need a cdl. So unless it is legitimate to raising or selling ag produce you need a cdl. Also campers or motor homes are exempt even a semi pulling a 45 ft camper would be exempt if not used for business just a personal camper.
With all the regulations how is the equipment rental business?  It is pretty big here for both homeowner and contractors renting from a rental yard.
2 comments
The camper exemption is a loophole for sure.  Not that I want retired guys to get a cdl for their motorhome but I've seen a lot of incompetent travel trailer drivers etc.  I worked at a campground in my youth.
I think the pickup and 10k trailer weight is pretty misunderstood.  With all the mini excavators and skid loaders being hauled around I suspect there are some illegal loads.
Good
A lot of contractors rent but you need the license to rent anything bigger than a compact tractor
The other business doing well is equipment transportation
1 hour ago, hobbyfarm said:
2 comments
Most of them are illegal. I didn’t know about the 10,000 lb trailer either until researching law. Makes any hobbiest pulling a medium size tractor around need a cdl.
And to add a little smoke to the fire....
When the regulation came out here a few years ago.
Language stated pulling a GN trailer (can't remember all the language) over I think 100 miles from home with the intent of making money required a CDL
This put most the ropers on the CDL list.
Raised quite a ruckus.
Pretty sure most didn't bother and never heard of any of 'em getting cited for it.
