IH 385 replacement clutch recommendation ?
skippydoo
My clutch pedal kept getting lower and lower so I pulled the inspection cover off and  round balls fell out.  My throw out bearing is shot and the pressure plate  fingers are  messed up a little.  Should I get oem parts  or some other brand?  Thanks!
Hy-capacity has a kit that has a new pilot bearing, throwout bearing, pressure plate, and clutch disk. All new, no core required.
