Farmall 300 tricycle Posted January 14, 2022 Share Posted January 14, 2022 I am having an issue with my tractor only running with the choke pulled all the way out. I can push it about half way in but then I cannot fully throttle it or it dies. If the chokes pulled out all the way then I can throttle fully. I am unsure of the issue Quote Link to comment Share on other sites More sharing options...
DT Fan Posted January 15, 2022 Share Posted January 15, 2022 Simple answer is it's not getting enough fuel. Have you checked the sediment bowl? Does it have an inline filter that could be plugged? Quote Link to comment Share on other sites More sharing options...
Red Tech Posted January 15, 2022 Share Posted January 15, 2022 It sounds like your spark plugs are dry carbon-fouled, which causes you to have to run a richer mixture (choke out). If they are, install Autolite 388 plugs, gapped at .025. Check your plugs 1st. If it is not this, then follow DT Fans advice Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted January 16, 2022 Share Posted January 16, 2022 Good suggestions above. Also carb could have a passage internally plugged. Quote Link to comment Share on other sites More sharing options...
rustred Posted January 16, 2022 Share Posted January 16, 2022 On 1/14/2022 at 11:03 AM, Farmall 300 tricycle said: I am having an issue with my tractor only running with the choke pulled all the way out. I can push it about half way in but then I cannot fully throttle it or it dies. If the chokes pulled out all the way then I can throttle fully. I am unsure of the issue start at the tank and follow the gas flow. should be running full line at carb like u drank 6 beer. if not remove and soak carb in gunk. Quote Link to comment Share on other sites More sharing options...
catman13 Posted January 17, 2022 Share Posted January 17, 2022 it may have a screen in the elbow where the fuel line hooks to the carburetor 1 Quote Link to comment Share on other sites More sharing options...
