D335/D350 Sleeves
IH OAK
A thought just occured to me...The D335 and 350 engines were either flush or protruding sleved. Was the difference in the sleeves or the block? Or was it just how you install them?
I am asking because I am in the process of buying a set from a member but I want to be sure they will work before He sends them.
the sleeves are protruding. plus they are pressed in and the standout has to be in spec. from .041 to .049 from top of block to top of sleeve. you probably have to build a puck to pull the old ones out.
All sleeves are protruding, there is one exception if I remember correctly and that is the 4.5 overbore kit IH offered for the D335, these are flush. All 4.4, IH and aftermarket, are protruding and the 4.5 aftermarket are protruding too.
Okay, when I ordered my head gasket they asked me if it was protruding or flush.
A local machinist friend is going to make one for me.
Have the machinist make an intallation  plate that will give the proper protrusion when intalking the sleeves too .
9 hours ago, td9inidaho said:
My understanding with those motors, they are dry sleeves and are to be adhered into place at the appropriate depths. That's the info I went by when I rebuilt my 350 anyhow. Theory has it they can't move up or down that way
Mark
exactly...the sleeve flange is bottomed out at the top of the block bore.  some had shims to put under the flange to get the height on all correct.   plus the fire ring on the head gasket is holding and sealing once torqued. just curious what is other tool is other than a dial indicator or feeler gauges.
So the sleeves DO have a flange on the top?
I don't need the installation ring suggested by @FARMALL FIXER???
yes they have a top flange. , no u dont need anything else. makes me wonder if these guys that post stuff have had their hands on what they are talking about., cause i have no idea what that is and asked then things go dead.
My understanding some gaskets/fire rings covered the liners, others did not, there for the ridge on the liner was the holding factor between the head and block. This be why the liners were "glued" to the block upon installation so they never migrated up and down. Yes they have flanges to set to the block. And as others have said shims available to make sure they seat high enough to meet specs, the glued in part many are not speaking of.  No big deal to me, just adding to the FYI pile
Mark
My TD-9 that we have apart, is the D335 with the 4.5 pistons and the flush mount.  We are trying to rebuild, but when we had the block dip’d we found out that it has a crack in it.  So, can you identify from looking at an engine, if it has the flush mount or not?  As, I already sourced pistons, liners and gaskets, for the 4.5 flush mount, and am now searching for a block.
Unfortunately, the plate is probably already made...waiting for me to go pay for it...I haven't heard back yet from the machine shop yet...
