89vmax Posted January 10 Share Posted January 10 Was driving it down the road the other day and rh brake got hot I've never had this issue before where do I start to fix it Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted January 10 Share Posted January 10 Sounds like your brake piston is sticking , I'd take it apart and inspect it Quote Link to comment Share on other sites More sharing options...
801486 Posted January 10 Share Posted January 10 Sometimes the insulator pad falls off the Piston and wedges in. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted January 10 Share Posted January 10 Start by making sure pins between pedal and valve are free and pedal adjustment is correct. Also pedal return springs. Quote Link to comment Share on other sites More sharing options...
DT Fan Posted January 10 Share Posted January 10 1 hour ago, snoshoe said: Start by making sure pins between pedal and valve are free and pedal adjustment is correct. Also pedal return springs. I'd check that spring first, happened to my 10. Simple fix too! Quote Link to comment Share on other sites More sharing options...
