RAH Posted April 7, 2022 Share Posted April 7, 2022 Karl does a great job! 1 Quote Link to comment Share on other sites More sharing options...
Allen Ulmer Posted April 17, 2022 Share Posted April 17, 2022 @twood1954 I heard the 460 is getting a make over in the kings shop too?! Quote Link to comment Share on other sites More sharing options...
twood1954 Posted April 17, 2022 Author Share Posted April 17, 2022 Yes give the King a call and he may tell you want he up to. Quote Link to comment Share on other sites More sharing options...
twood1954 Posted May 2, 2022 Author Share Posted May 2, 2022 Cage is done and mounted on tractor. Will be interesting to see how much total weight was lost. 3 Quote Link to comment Share on other sites More sharing options...
560Dennis Posted May 22, 2022 Share Posted May 22, 2022 What kind of foam insert for differential oil reduction do they use ? Quote Link to comment Share on other sites More sharing options...
twood1954 Posted May 22, 2022 Author Share Posted May 22, 2022 I don't know. I have pressure lube rear end so only run 2 to 3 gallons of hy tran. I have heard of issues long term with foam. My tractor has run this system since 94. Good luck. Quote Link to comment Share on other sites More sharing options...
560Dennis Posted May 23, 2022 Share Posted May 23, 2022 10 hours ago, twood1954 said: I don't know. I have pressure lube rear end so only run 2 to 3 gallons of hy tran. I have heard of issues long term with foam. My tractor has run this system since 94. Good luck. Thanks for the tip Quote Link to comment Share on other sites More sharing options...
twood1954 Posted May 29, 2022 Author Share Posted May 29, 2022 Looks like we lost 200 lbs off the rear end. That's what we were hoping for. 4 Quote Link to comment Share on other sites More sharing options...
twood1954 Posted June 17, 2022 Author Share Posted June 17, 2022 When across certified scale last Saturday, the good news is total weight loss was 300 lbs. Tractor 285 lbs. and driver 15 lbs. so far. 6 Quote Link to comment Share on other sites More sharing options...
Allen Ulmer Posted September 4, 2022 Share Posted September 4, 2022 @twood1954have you made it to many hooks this summer? Quote Link to comment Share on other sites More sharing options...
twood1954 Posted September 5, 2022 Author Share Posted September 5, 2022 No about 6 hooks or tries. Lots of little issues and rain. How about you. Quote Link to comment Share on other sites More sharing options...
