TD6 bucket lubricator
Cully4x4
Reading through the owner/operator manual for my 1945 TD6, it mentions using a “bucket lubricator” versus a hand pump lubricator for certain parts. I am not familiar with such a lubricator (other than one that pumps grease through the normal grease fitting). So, what is the difference? A different type of grease fitting? Or just the volume of grease being pumped. I can’t find any examples of an antique bucket fitting that description via google search. Anyone in this forum heard of, or can describe, such a bucket? Thanks.
The bucket was just that
The fittings commonly found in certain areas are an Alemite button head fitting can't recall the number that were far less prone to getting sheared off in high risk locations (tracks) #3 or 5 is ringing a bell
The manual doesn’t specify anything except that the bucket lubricator is supposed to be used. Do you have any idea which coupler is to be used….#3?  #5?     How wide is the channel that the coupler needs to be to fit the grease fitting?
IIRC they're "Giant Button" fittings and they had protective ears in the bits around them on the frame etc
Maybe I asked the question in the wrong fashion. Is there a specific size (other than giant fitting) that the coupler on the grease gun/bucket need to be? Thanks.
9 hours ago, Dirt_Floor_Poor said:
I have used corn head grease in all kinds of applications that can use 90W or heavier oil. It is almost impossible to run something dry that has corn head grease in it because it will leak out so slow. You have time to see the leak. Corn head grease is grade “0” grease.
Okay. Good info from everyone. Thanks.
I bought a low pressure, hi volume grease gun from alemite and put a button coupler on it. I have a bunch of Grade 00 grease that came from an auction once so that`s what I use on my TD6. Its a little thinner than corn head grease which is grade 0
