sandhiller Posted January 2, 2022 Share Posted January 2, 2022 Got a F20 with 6.00-16 on a narrow front that need replaced. I would like to go with a little wider tire. Would a 6.50-16 or 7.50-16 fit the rims? Would they rub anywhere? On the back end of a forklift with a weight box so they do carry some weight. Thank you, Jeff Quote Link to comment Share on other sites More sharing options...
12_Guy Posted January 2, 2022 Share Posted January 2, 2022 An F-20 reversed to make a forklift?? Pics please. As for the tires, I assume the 6.50 would be fine. The 7.50 might be ok if you can get them on the rim. Sorry I’m not better help. 1 Quote Link to comment Share on other sites More sharing options...
bitty Posted January 2, 2022 Share Posted January 2, 2022 On Uncle George's M they have had 7.50-16 for years . Two bias ply digger truck tires might be better weigh carrying but I don't know what clearance difference is on the F series. Think it's something you want to mount to the rim while on the tractor as you have to undo it at the wheel bearing otherwise? 1 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 56 minutes ago, 12_Guy said: An F-20 reversed to make a forklift?? Pics please. As for the tires, I assume the 6.50 would be fine. The 7.50 might be ok if you can get them on the rim. Sorry I’m not better help. Has a chevy 250-6 motor. 7 1 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 24 minutes ago, bitty said: On Uncle George's M they have had 7.50-16 for years . Two bias ply digger truck tires might be better weigh carrying but I don't know what clearance difference is on the F series. Think it's something you want to mount to the rim while on the tractor as you have to undo it at the wheel bearing otherwise? I glanced at wheels in passing with that in mind. Need to give it a closer look. Something to think about for sure. Quote Link to comment Share on other sites More sharing options...
hardtail Posted January 3, 2022 Share Posted January 3, 2022 Is this the first piece of construction equipment that was merely uttered yesterday? You don't even have the locomotive home yet to hide it with 😬 I will say no moss grows around your hacienda...😁 4 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 3 minutes ago, hardtail said: Is this the first piece of construction equipment that was merely uttered yesterday? You don't even have the locomotive home yet to hide it with 😬 I will say no moss grows around your hacienda...😁 With -18 last night, the moss is all done frozed up🥶😁 1 1 Quote Link to comment Share on other sites More sharing options...
1586 Jeff Posted January 3, 2022 Share Posted January 3, 2022 1 hour ago, sandhiller said: Has a chevy 250-6 motor. Be still my beating heart!!!! That is soooo ugly that it is beautiful!!! How well does it go in soft ground? 2 2 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 4 minutes ago, 1586 Jeff said: Be still my beating heart!!!! That is soooo ugly that it is beautiful!!! How well does it go in soft ground? LOL, I had people at gas stations on the way home smile and chuckle when they saw it😆 Ground has been froze since I got it home so not sure about soft ground. It ain't terrrible on snow and ice but I will need to chain it up if it gets any worse. 1 Quote Link to comment Share on other sites More sharing options...
12_Guy Posted January 3, 2022 Share Posted January 3, 2022 Round spokes all around, nice! Looks like somebody had fun building the ol girl. Like Bitty said, probably easier to mount the tires on the tractor. Probably the only easier way would be to replace the spokes with the later cast center wheels with the removable rims. 1 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 38 minutes ago, 12_Guy said: Round spokes all around, nice! Looks like somebody had fun building the ol girl. Like Bitty said, probably easier to mount the tires on the tractor. Probably the only easier way would be to replace the spokes with the later cast center wheels with the removable rims. The gentleman that did the conversion did a real nice job. Well thought out and executed. The Chevy six looks like it belongs in there and all controls are easy to get to. The only thing I would like to change is the exhaust. I think it was added later as it doesn't fit the rest of the work. I would like to run it close in and up behind the hyd res to clean it up. The round spokes all around I think I will keep. 1 Quote Link to comment Share on other sites More sharing options...
Frank H Posted January 3, 2022 Share Posted January 3, 2022 Well that's sure different......neat forklift! 1 Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 3, 2022 Share Posted January 3, 2022 17 hours ago, sandhiller said: I glanced at wheels in passing with that in mind. Need to give it a closer look. Something to think about for sure. Jeff, by the looks of the weight box It don't look like you could stand a much bigger Tire Hight wise just going by the photos you posted How about some wide steel wheels?? Just kidding Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 33 minutes ago, m.c.farmerboy said: Jeff, by the looks of the weight box It don't look like you could stand a much bigger Tire Hight wise just going by the photos you posted How about some wide steel wheels?? Just kidding Probably best to stick with what was on there. Found some Carlisle's that have a wide center rib that looked pretty good to me. I have a personality disorder of always trying to go bigger and wider. 1 Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 3, 2022 Share Posted January 3, 2022 2 minutes ago, sandhiller said: Probably best to stick with what was on there. Found some Carlisle's that have a wide center rib that looked pretty good to me. I have a personality disorder of always trying to go bigger and wider. Thats a Male thing!! we can all wish 1 Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 3, 2022 Share Posted January 3, 2022 18 hours ago, sandhiller said: I glanced at wheels in passing with that in mind. Need to give it a closer look. Something to think about for sure. Looks like the mast doesn't have tilt cylinders Iam missing something? Quote Link to comment Share on other sites More sharing options...
oleman Posted January 3, 2022 Share Posted January 3, 2022 18 hours ago, sandhiller said: Has a chevy 250-6 motor. All it requires is a hydraulic reverser! 1 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted January 3, 2022 Author Share Posted January 3, 2022 1 hour ago, m.c.farmerboy said: Looks like the mast doesn't have tilt cylinders Iam missing something? Think this shows it. more pics in the PB&R sub forum. Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 3, 2022 Share Posted January 3, 2022 Just now, sandhiller said: Think this shows it. more pics in the PB&R sub forum. I see said the blind man! Thanks 1 Quote Link to comment Share on other sites More sharing options...
jimw Posted January 3, 2022 Share Posted January 3, 2022 Can’t believe u didn’t think we would want to see pictures? 😉, cool outfit. Pretty good shape for as old as it is. 1 Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 3, 2022 Share Posted January 3, 2022 20 minutes ago, jimw said: Can’t believe u didn’t think we would want to see pictures? 😉, cool outfit. Pretty good shape for as old as it is. it is a cool build that man put a lot of thought into it good score hiller 1 1 Quote Link to comment Share on other sites More sharing options...
