McCormick-Deering 10-20 dating information
A question for people who know their way round 1920 to 1939 McCormick-Deering tractors, particularly the 10-20 & 15-30.
Where do I look for Casting Codes and Engine serial numbers on these old tractors?
I have learned from experience of that serial number plates are either missing or unreadable on these very old machines.
I know that casting codes didn't exist before 1931 but engine serial numbes can help approxiamately date a tractor.
Regards from Michael H.🔧 in Australia.
5 hours ago, rustred said:
crawl under it and look up at the front on the transmission housing. it the date month and year is stamped right there.
I'll try that. I remember my uncle used to have an restored 10-20. I was told it was a 1926 model, the serial number plate was missing, but underneath I found the stamp you mentioned. From memory it said "TW ?? ??26" which may mean "Tractor Works ?? 1926"
it will look like this...... 03-22-28 which is  march 22 1928 as an example. i was gonna take a picture of mine but was too busy. try tommorow.
I have found it. The tractor is a 1930 build. That tag, once I cleaned the grease off it, reads "*.18.30", The first digit is unreadable.
The serial number plate is missing but I found the engine number KC 178315, which suggests 1930 build year.
Regards from Michael H. 🛠️
