Tnhardin Posted December 19, 2021 Share Posted December 19, 2021 Looking for the torque for the bolt that holds the finger clamp on the injectors. Recently bought the 1066 and haven’t gotten the service manual for it yet after internet search came up empty. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Tnhardin Posted December 22, 2021 Author Share Posted December 22, 2021 Anybody have any idea? 2 Quote Link to comment Share on other sites More sharing options...
Injpumped Posted December 22, 2021 Share Posted December 22, 2021 tighten it up, 5/16 gr8 bolt, about 25ft lbs 1 Quote Link to comment Share on other sites More sharing options...
Tnhardin Posted December 22, 2021 Author Share Posted December 22, 2021 Do the bolts need to be replaced with new ones? Quote Link to comment Share on other sites More sharing options...
Tnhardin Posted December 22, 2021 Author Share Posted December 22, 2021 Here's another one of my tractors. 1962 Ih 404 pulling a ih 56 4 row last spring. Probably isn’t the right place to post pictures, but hey I’ll share anywhere. 4 Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted December 22, 2021 Share Posted December 22, 2021 I never torque those , when your an old mechanic with years of experience like I am you tighten certain fasteners by feel 1 Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted December 22, 2021 Share Posted December 22, 2021 11 minutes ago, Tnhardin said: Do the bolts need to be replaced with new ones? No nothing wrong with reusing the same hardware I get irritated when suggested that new bolts be used for simple things , That's Bull Quote Link to comment Share on other sites More sharing options...
Tnhardin Posted December 23, 2021 Author Share Posted December 23, 2021 I’ll go with the 25 ft lbs. that’s about what I figured. I appreciate the help. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted December 24, 2021 Share Posted December 24, 2021 Be sure the correct clamp and bolt/washer combo are used. If you look, the clamp where the bolt goes through is beveled. There is a heavy washer that is beveled to sit in the bevel. I believe there are two different styles, but I have only seen the bevel washer style. Quote Link to comment Share on other sites More sharing options...
hippy5488 Posted December 24, 2021 Share Posted December 24, 2021 20 ft lbs is proper torque 1 Quote Link to comment Share on other sites More sharing options...
Maynard Posted December 25, 2021 Share Posted December 25, 2021 On 12/24/2021 at 9:20 AM, hippy5488 said: 20 ft lbs is proper torque Correct, but a little extra doesn't hurt if needed. On 12/23/2021 at 11:18 PM, MinnesotaFarmall said: Be sure the correct clamp and bolt/washer combo are used. If you look, the clamp where the bolt goes through is beveled. There is a heavy washer that is beveled to sit in the bevel. I believe there are two different styles, but I have only seen the bevel washer style. Here's the explanation on the different bolt and washer combinations. 1 Quote Link to comment Share on other sites More sharing options...
Tnhardin Posted December 25, 2021 Author Share Posted December 25, 2021 Appreciate y’all’s help. I still have the displaced style and noticed they had to be put in the correct order. Thanks again. 1 Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted December 27, 2021 Share Posted December 27, 2021 On 12/25/2021 at 2:39 PM, Maynard said: Correct, but a little extra doesn't hurt if needed. Here's the explanation on the different bolt and washer combinations. A lot of us learned something here. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
